mickkell
- Feb 11, 2021
- Peoria AZ.
I need a little advice/help during reassembly of the Shaft that drives the Carriage/x-axis I guess, back and forth. There is a Plunger on the side that contacts the shaft, there is a Spring inside there thats in the way of installing it. There must be a trick to it? Does the little ball go into the hole in the shaft? What is the Plunger suppose to do? TIA
