Brand new mill table hardness dilemma.
Results 1 to 15 of 15
    Aug 2018
    CANADA
    British Columbia
    5
    Default Brand new mill table hardness dilemma.
    Does anyone know if there is a standard typical hardness, or any information for milling machine tables?
    Long story short. We have recently purchased a new Fortworth csvbm-5vl, and the table is incredibly soft. Our other mill tables test out at about 55-60 rockwell C, but this fortworth shows 20 rockwell C. This is makes it very difficult to not damage as even a single chip caught under a parallel, or a toe clamp bolted directly to the table will cause a large dent.
    I cant recall any of the shops i have been to needing to put parallels under a toe clamp in order to not damage the table.
    The supplier claims that this is actually a feature for superior vibration dampening, and to not mark up the parts youre machining. (hardened parallels and vise jaws seem to go against the "marking up parts" theory.. no?...)
    They follow this up with saying these benefits outweigh the con of having to resurface the table with a stone every so often. I strongly disagree.
    Anyways, has anyone else experienced this? have any suggestions? Is there any companies that create custom meehanite tables?
    Mar 2013
    Washington
    215
    117
    163
    Interesting
    I personally work around old school manual machines ive never heard of or seen a machine tool with a HARD work surface only hard ways
    Chips under anything are a big no no in every shop I've worked at but whatever
    What machine do you have that has a hard work surface
    Got a pic or two ?
    Jul 2006
    Hillsboro, New Hampshire
    5,084
    1194
    3568
    55-60RC is near bearing ball hardness, much harder than I'm used to seeing in my machine tables. But cleanliness should be a given when setting materials or vises down, surely you'll ding a vise base if clamping on a chip rather than cleaning properly first.
    I'd look at your procedures and standards for cleaning before I'd get so concerned about table hardness.
  4. Likes Kaszub, sfriedberg, Paolo_MD liked this post
    Aug 2018
    CANADA
    British Columbia
    5
    i understand chips are to be cleaned. i was using it as an example of how easy this table is to damage, not that we clamp chips into our setups.
    either way, simply tightening 2" wide toe clamp down, will cause a 2" wide dent.
    the other machines in question with the hard tables are TOS FGS's
    our Kent also has a significantly harder table
    Jul 2006
    5,084
    1194
    3568
    Well, the toe clamping does sound too soft, my Haas's aren't great machines but the tables will take that sort of use. But if it's an edge load I'd still use a Al plate under the clamp edge just as good practice.
  7. Likes Paolo_MD liked this post
  8. #6
    Nov 2002
    St.Louis, Missouri, USA
    1,964
    116
    437
    I haven't a clue (never checked) as to how hard my tables are but I know I can stone or file a riser down with relative ease.
    We used to have all the large mills with over size aluminum sub plates permanently bolted down with hardened 1/2" bushings for pins and four 1/2"-13 inserted bolt holes around each pin hole. They used them 24-7 for years on end with only ever removing them if it was required to get to something broken on the machine. I can't see how your cast iron table could be any softer or more easily damaged than those?
    Dan
  9. Likes sfriedberg, Paolo_MD liked this post
  10. #7
    Jul 2006
    5,084
    1194
    3568
    This video: FORTWORTH Model :CS VBM 5VL Vertical Boring and Milling Machine - YouTube shows the machine to be a Taiwanese bed mill, if it was pretty cheap to purchase then perhaps not that surprising on the quality or processing of CI used.
  11. #8
    Aug 2018
    CANADA
    British Columbia
    5
    Tried to edit my post. Ended up deleting it. Whoops
    I guess we have been spoiled with our previous mills. 30 years old and the tables still look brand new.
    Yes the machine wasn't too pricey. $100 000 to our door.
    How soft the table is just seems very foreign to me. Not what I had expected there. However the rest of the machine is great. No complaints other than the table
  12. #9
    Jul 2006
    5,084
    1194
    3568
    Wow, that much? Of course in Loonies, but still. I don't usually say this, but did you check out a Haas of roughly the same size? Did you require an open-frame machine for your needs?
  13. #10
    Dec 2014
    New York
    748
    245
    182
    Quote Originally Posted by DTM0 View Post
    Mayabe a sub plate would help?
  14. #11
    Dec 2014
    New York
    748
    245
    182
    Right there with you , sounds a lot for the machine in YouTube video.
  15. #12
    Jul 2006
    5,084
    1194
    3568
    Quote Originally Posted by Kaszub View Post
    Yeah, but the Can buck is about (or aboot) 75% of a US dollar, so that's roughly $75K here (or less). I don't know what the equivalent Haas would go for, but perhaps another $20K or so. And if they need open frame, you'd have to remove the shielding and fudge the safety interlocks, that may be a no-go for their purposes.
    But having a tool changer makes so much of a difference in functionality, I wouldn't buy a machine without one unless I absolutely had too.
  16. #13
    Mar 2013
    Washington
    215
    117
    163
    Sounds scary to me
    What's going to happen in a crash
    Good luck
  17. #14
    Aug 2018
    CANADA
    British Columbia
    5
    It may seem like a lot. But try getting anything to your door in Canada. You'll find its a pretty good price for what you get.. hell a 8" Kurt vice is 2000 alone. Oil skimmer? Another $600.
    Yes it has the pneumatic draw bar.
    My only gripe is how soft the table is.
    Anyone have hardness testers? I'm curious as to what other people's machines test at.
  18. #15
    Aug 2018
    CANADA
    British Columbia
    5
    Also factor in tooling. Taxes. Etc
