nearbeer
- Jul 29, 2009
- Greenville, SC
Hello all and thank you for your time.
I've been slowly disassembling and cleaning up a Bridgeport 2J mill; everything was proceeding smoothly until now. My focus has been getting the ram to slide off of the turret and it has not budged one bit; there is a significant amount of surface rust on the turret & ram ways.
I removed the ram pinion, the ram lock bolts/studs, and the locking pins that hold the turret to the spider. The ram and turret are completely off of the vertical column; the head I pulled off last year and the only other part attached to the ram is the ram adapter.
A few weeks ago I tried bolting the turret to the garage floor with 1/2" anchors and using a bottle jack tilted at an angle to try to get the ram to move; I don't think I had the angles right and too much of the bottle jack force went to lifting up the back end of the ram off of the anchors and not enough force along the ram's long axis.
I have looked at the underside of the turret and can feel the ram clamps moving freely about a pin; I don't believe that is what is keeping the ram from sliding along the turret.
Have I removed everything from the ram and turret that would keep it from sliding? I am at the point where I am going to get some scrap c-channel and tube to build a rack/cage that will allow me to move the ram/turret into a vertical position; I will weld some c-channel 10-12" behind the ram to act as a backstop/brace for the bottle jack while it presses against the end of the ram.
I have put several applications of PB blaster, 3 in 1, etc type of lubricants on the ways in hopes that they will creep into the horizontal part of the ways but it has not helped. I have built a plywood box to act as a tub for electrolysis removal but I am not sure that electrolysis is going to help at this point and I want to avoid the mess if able.
Again, can you identify anything that is keeping the ram from sliding along the turret?
Thanks and still haven't found my next cold one,
NearBeer
NearBeer
