rimcanyon
- Sep 28, 2002
- Salinas, CA USA
I am working on a 59 Monarch 10EE that had been very poorly rebuilt at one point. Oil grooves (on the front saddle V-way) were machined that run straight from left to right, no zig-zags. As a result, the bed had worn a ridge along a considerable length (matching the oil groove). So the bed was replaced with a used bed that had very low wear. Now I need to decide about the replacement saddle. I have three 10EE saddles. The one with the straight oil groove. Another which is perfectly normal (including zig zag oil grooves) except it is worn convex, so it rocks quite a bit (.020"). And a third which came from Mare Island that has the ways built up with delrin and has no oil grooves. The one from Mare Island is a perfect fit to the bed; I used it as the sled for an autocollimator target when I fitted the bed to the base.
So I think I should scrape down saddle #2 and fit it to the bed. Saddle 1 is beyond help. Saddle 3 with the delrin has no oil grooves and oil grooves cannot be cut in it, if my understanding of built-up surfaces is correct. However, .020" is a lot, and it gets to my real question. Is .020" enough that I will also need to remove metal from the top of the apron (and then shave the gear on the cross slide screw)?
