As the others suggest, remove it and clean it up, understand how it works. Then assemble it on the far end so you can look under there when making the adjustments. If it is really worn it may not be clamping on the ways, so be a detective and use a .002" feeler gage and test to be sure it is touching and clamping where it should.
