HobbyMaker
- Feb 5, 2021
I'm chasing some advice & opinions on paint removal & paint selection and paint colours for a 1960 Nuttall Lathe. All tips, tricks, pictures of restored machines & colour codes would be appreciated.
Whilst I understand this is very subjective I was hoping to avoid any pitfalls or common mistakes
Background
I picked up a cheap 1960 era Nuttall Lathe and am slowly working through cleaning it up and ironing out the problems to get it up and running. This is a hobby project so budget is fairly small, but as I work through the parts I would like to give them a coat of paint to restore the machines looks as well as its functions.
This is not aiming to be a mint condition restoration but more a functional cleanup and improve the presentation along the way.
The machine has had several coats of paint in its life which are starting to peel and flake. Whilst anything I remove from the machine can be fairly quickly cleaned back the body maybe tricky given its weight and location.
Original internal colour appears to be some form of red and the external colour have been a blue grey but its really hard to tell.
Questions
Background
Questions
- What is the best way to remove paint?
- From the main body as this is hard to move?
- From the removable components? (Currently been mostly working with wire brush on a bench or angle grinder)
- What standard cleanup would you recommend for a good finish without spending unrealistic time (are there any short cuts or tricks that can be taken without compromising the end result)
- What is the best paint to use?
- Enamels, 2 pack epoxies, acrylics etc (I was hoping to get away with an enamel as I can both brush and spray these reasonably simply and they are good with the budget)
- Primers & fillers
- Spray vs Brush (I can spray the parts that are removed but the body maybe harder given its location and was thinking a brush on solution maybe the way to go)
- Colours?(Photos please)
- Does anyone know the original colours of a 1960 Nuttall Lathe?
- What are go to colours for lathes & mills of other brands?
- What non-orignal colours look great?
My primary aim is doing this machine up for myself (but I still don't want to paint it a colour that would make it hard to sell it the future.) I saw someone suggest white looks great and someone else suggest black (but saw images of a cream coloured Bridgeport mill that the owner couldn't sell because of the colour.) - I was hoping to do this over a period of time as and when I either had the part off or the time available to tackle one of the major components
