Hello all!
I am repairing an antique Brilliant vacuum, and it only had one wire going into the stator. It had a small rubber box coated in metal bolted next to it, which had one going into and one coming out of it. The wiring was very confusing but pretty much everything tells me there is supposed to be 2 going in there. Also, one of the brush wires pulled right out when I took it apart. It is a rather small motor, and no replacements are available as it is literally one of two known in the world. The ratings are AC 110, 60 cycles. What would an estimate be for a rewind?
Thank you!
Thank you!
