Curtis air compressor rebuild question
Likes Likes:  0
Results 1 to 4 of 4
    Oct 2010
    MO, USA
    293
    138
    93
    Default Curtis air compressor rebuild question
    I bought a used Curtis compressor a while back. It is a C 98. It was running when I bought it but it was under a lean to on the side of the guys building. It came up to pressure fine and seemed to operate as I think it should but it looks rough.
    I would like to have it gone over by someone that is more knowledgeable about these than myself.
    I am going to replace my Ingersol Rand 5 HP vertical unit with this one. The IR just isn't made for the strain I am putting it under.
    Can anyone recommend a reputable outfit that would be able to handle this. If it needs to be rebuilt that's fine I just want it to get done right.
    Oct 2010
    MO, USA
    293
    138
    93
    Has anyone here rebuilt one of these? If I attempt to do it does anyone know of a good source for parts or info about these?curtis-2.jpgcurtis-1.jpg20181106_114042.jpg
    Jan 2011
    BFE Nevada/San Marcos Tx
    989
    867
    509
    Never a Curtiss, but I've rebuilt several compressors of same vintage. If you've rebuilt an engine, you can rebuild a compressor. Google showed several suppliers for Curtiss parts, if they do not carry parts for that model you are stuck with disassembling, then searching for parts by dimensions. Unless you find something wrong internally, you can probably get by with a valve job and some new rings, and maybe a set of main (roller) bearings.
    Jan 2008
    southern il
    858
    142
    293
    I'd give it a good inspection, check bearings and journals, wouldn't rebuild the bottom end unless warranted. Take the head apart and clean the valves, they get gummy from years of oil residue and whatever.
