bellaireroad
- Oct 4, 2015
Hello,
I would appreciate some guidance on removing the gearbox pulleyon a Delta 28-365 bandsaw. There is a collar (254)that holds the pulley on. The collar has a set screw (255). Problem is the collar is inside the pulley, how to get to the setscrew? Also, there is a keyway in the pulley with no key, I’m not sure what that’s for. Thank you for your advice
