partsproduction
Titanium
- Aug 22, 2011
- Oregon coast
My brother and I have been scraping in a lathe, and had to make a new gib, taper type. It's for the compound rest so is only 7 inches long and maybe 3/8" thick at the thick end. We noticed that it was bent, so I peened the low end to straighten it, worked like a champ. I was afraid to try to bend a thin piece of cast iron, concerned that it might break.
Well, we found we were beating a dead horse as we tried to scrape it to final coverage as the thick end was about .002" too thick, which we discovered doing a shake test, so I lengthened the stroke and ruthlessly destroyed much earlier work on the thick end so we would stop wasting time.
The work went fast after that but I kept having to scrape the ends, and an alarm ell went off in my head because it was straight, wasn't it? A knife edged straight edge revealed a wow and in the end I straightened it by bopping it with my palm with one end in the vise.
Anyway, I reason that the hard scraping actually went below the peened compressed layer, and as we kept scraping it just got worse and worse. Anyway, I wanted to ask if anyone else had had the same experience, and if bending it the scary way of straightening a gib is therefore considered the answer.
parts.
parts.
