G & L rebuild - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
Thread: G & L rebuild
  1. #21
    Oct 2014
    Maryland
    2,481
    1767
    1897
    Brian Bloc
    https://www.practicalmachinist.com/vb/members/brianb/
    bcbloc02 YouTube on youtube has a similar HBM.
    he might be able to answer some of your questions
    dee
    ;-D
  2. Likes gear cutter liked this post
  3. #22
    Apr 2006
    Manchester, England
    8,254
    1200
    5228
    Quote Originally Posted by gear cutter View Post
    Here's some pictures of the machine in my shop.Attachment 248943Attachment 248944Attachment 248945
    That's a nice clean shop. Have you built an Hor a Bore before ?
    Regards Tyrone.
  4. Likes gear cutter liked this post
  5. #23
    Jul 2005
    Cottage Grove, MN 55016
    7,598
    4095
    4540
    One of the photo's show the table on the saddle and bed and the outboard support sitting next to the machine. I would suggest you slide them under the saddle and rough level it for now so the saddle and table don't twist. Also when you place wood under parts on the floor place the part on 3 points at 30% : 40% - 30%. I have been writing about this on PM for years. If your in a hurry 2 x 4' or 6 x 6 at 30% is better then on the ends. 3- points will self level like a transit. If you have a surface plate on a stand, look under the plate. Expensive Grade A surface plates set on 3 points to eliminate twists.
  6. Likes gear cutter liked this post
  7. #24
    Aug 2006
    Shelbyville, Ky
    497
    44
    182
    I hope you got more big pieces than what is in picture 3 as you are missing some large parts. Did you try contacting G&L? They should be able to get you a manual from your serial number. They were able to provide me with one and a foundation diagram for my 340T.
  8. Likes CBlair, Richard King liked this post
  9. #25
    Sep 2019
    New Jersey
    8
    Thanks Dan! I work for LUBE USA!
  10. #26
    May 2005
    Republic of Arizonia
    1,583
    465
    Well, if blakelyj2 is gonna bump the thread, I'm going to ask...
    Did you ever get it back together? and What was your final solution for oiling the machine?
  11. #27
    Apr 2006
    Manchester, England
    8,254
    1200
    5228
    That's good. If it was my machine I'd block up the free end of the cross travel leadscrew before it gets damaged.
    Regards Tyrone.
  12. #28
    Mar 2011
    Geneva Illinois USA
    6,165
    2621
    2390
    You need some more machines in there. Those two look awfully lonly.
    Tom
  13. #29
    Sep 2019
    New Jersey
    8
    Quote Originally Posted by Cole2534 View Post
    Are their items a direct cross for Bijur components? That'd be great!
    Many of our items do cross over directly from Bijur(I work at lube USA)
  14. #30
    Dec 2012
    AUSTRALIA
    2,093
    9
    630
    A cheap positive pressure oil pumping system I ve used many times is an injector pump off a diesel engine......rotary or inline .....but with an inline(Bosch PE type),you can ,if you are keen) adjust the individual plunger outputs,as well as using the rack to controll the whole lot.Rotary pumps will be on full delivery all the time,unless you delve indside them,and get to the metering valve.
  15. #31
    Oct 2010
    MO, USA
    298
    145
    95
    Quote Originally Posted by JS View Post
    Not yet I am stuck at the lube system still. I've been really busy and haven't had time to work on it. I guy from Lube U.S.A. is supposed to come by the shop when he has time or is in my area. I am missing some of the table clamping parts so I will need to figure that out. The man that started the rebuild bought new gibs and scraped one side of each one. I will have to finish and fit them.
