ballen
- Sep 25, 2011
- Garbsen, Germany
This is the workhead base from a Studer RHU-450 cylindrical grinder that I am fixing up.
The round hole on the left-hand side is for a "locator pin" that is meant to index the workhead into the position where the rotation axis is parallel to the work table feed direction. After rescraping and realigning this is quite a bit offset from the correct location. So my question is, what's a good way to fix it?
The pin is 12mm (15/32") in diameter, case hardened and ground. At the end it tapers to 11mm (7/16") at a 1:20 ratio. I am not sure if the taper part is meant to be part of the location or just to help guide the pin into engagement.
One way to fix it would be to bore out the hole, glue in a cast iron plug with some loctite, then carefully locate the new hole, bore it out slightly undersize, then modify a 12mm reamer and pass it down. Or grind down an MT1 or Jarno 4 reamer (which have 1:20 taper ratios) and use that.
Another approach would be to bore out and roughen the hole, then turn the workhead+base assembly upside down, coat the locating pin with mold release, and fill the area around the locator pin with some steel-filled epoxy.
Is there a standard solution that works well?
