Hello Folks:
I have a Graziano SAG 14 lathe that the front head bearing is failing. Lathe is Ser # SAG14N9717-HB509. The head bearing is made by Gammet and I have located replacement. I have found no information on the procedure to change it and to set the preload. I do have have the extremely detailed parts manual which was use full at ordering the replacement bearing however it is not a service manual. I searched and and found no detailed service manual for the machine. If anyone has any experience with this operation I sure would appreciate any direction or suggestions to avoid any pitfalls.
Any information would be greatly appreciated
Thank you
Jon
Thank you
Jon
