cobbonthecorn
- Dec 30, 2014
- Michigan, USA
I have a knee mill that uses step pulleys to change spindle speeds. (Basement ceiling is too low for a "real" milling machine.) The original belts started to crack so they needed to be replaced. The original belts were made by SquareKnot or something like that, are Series B V-belts, and were very rigid in tension. The only belts I could locate locally were Gates. The issue is the Gates belts seem to be too "soft". That is they tend to stretch under load and this results in chatter that I didn't have before the belt change. Any suggestions for replacement belts? Thanks in advance!
