I have an old tailstock with a stuck ram. What are the best ideas to loosen it?
Page 1 of 2 12 LastLast
Results 1 to 20 of 24
    Oct 2014
    Maryland
    2,458
    1756
    1885
    Default I have an old tailstock with a stuck ram. What are the best ideas to loosen it?
    I have the endcap and the screw removed. I filled it up with PB Buster last night let it soak overnight. I also heated the outside until the stuff got to a boil.
    Should I try to press it out? Let it soak more, more heat? Open for suggestions.
    dee
    ;-D
    Aug 2012
    California, Central Coast
    3,329
    2153
    1296
    Double post.
    Aug 2012
    3,329
    2153
    1296
    Time is your friend, use it. Let it soak for a long time. Up to a month, depending on how bad. If a lot of rust has grown between the ram and the bore there may be no helping it. Completely submerge it might help.
  4. Likes dcsipo liked this post
    Sep 2010
    moscow,ohio
    5,905
    579
    1889
    knowing/seeing the design would help w/ regard to suggestions.
    Dec 2016
    Kentucky
    208
    34
    70
    Air hammer not to break it loose just to set up some vibrations to get the PB into more places
  7. Likes dcsipo, JohnEvans liked this post
  8. #6
    Oct 2014
    Maryland
    2,458
    1756
    1885
    Quote Originally Posted by Rob F. View Post
    I have the cavity behind the cap completely filled. I guess submerging would give it two ways. I need to see if I have enough PB to do that . The outside is CI, the Ram might be steel but do not know. You say patience grasshopper I guess I have to let it sit till it decides to come out. What about heating it periodically? I think that would expand the tailstock sleeve before it gets to the ram. PB is nasty when it boils
    dee
    ;-D
  9. #7
    Sep 2002
    People's Republic
    2,958
    213
    2055
    I think I would:
    make sure the clamp is not binding or rusted on. I would be afraid force might break that part of the casting if it was the last thing holding
    see if the key can be removed with ram in place
    continue soaking
    using a brass drift and a, say, 12 ounce steel hammer, give it a whack on an occasional basis. Somewhere just below smite a mighty blow
  10. #8
    Aug 2012
    3,329
    2153
    1296
    Try to heat the housing fast so it can expand before the ram warms up and expands with it. Be sure to heat the casting evenly though. Light vibrations as mentioned earlier could also help. A 5 gal bucket of diesel to submerge it in might help. Another way would be a strong plastic bag with all excess air sucked out, minimal oil is needed that way.
  11. Likes dcsipo liked this post
  12. #9
    Oct 2014
    Maryland
    2,458
    1756
    1885
    Do you mean like a kitchen vacuum sealer? Hmmm PB tasting chicken ... The wife would not be happy.
    dee
    ;-D
  13. #10
    Langley, B.C.
    1,641
    327
    961
    What lathe is the tailstock for? And how badly do you need to save it? If it's rusted up as badly as it seems chances
    are it will never be a precision fit again. I suppose it would depend on what you wanted to use it for.
    If you do get it apart and really need to use it you could line bore the housing and make a new spindle but that's gonna
    be a lot of work...
  14. #11
    Aug 2012
    3,329
    2153
    1296
    Quote Originally Posted by dcsipo View Post
    dee
    ;-D
    Squeezed out might be a better description. Wrap the bag of oil with shrink wrap.
  15. #12
    May 2002
    South Central PA
    13,448
    2176
    3372
    Let it soak more, let the PB work.
    I had 2 2" dia pins rusted into steel mounts, a 10 ton ram just bent the mounts without budging the pins. Sprayed Kroil on them periodically for 2-3 days, on the 3rd day a moderate swing with a 2 lb hammer moved them easily. The longer the engaged length on the ram the longer it will take for the PB to work it's way in. I haven't found high heat to help with penetrants, seems to just boil them off.
    How big is the ram?
    I'd try to make a way to press on it rather than impact it.
  16. Likes dcsipo liked this post
  17. #13
    Apr 2006
    Manchester, England
    8,112
    1156
    5096
    What sort of lathe tailstock is it, a little " Colchester Student " or a massive " ride on the saddle " Craven " etc ? A couple of photos would be a great help.
    Regards Tyrone.
  18. #14
    Mar 2011
    Geneva Illinois USA
    6,040
    2523
    2341
    Make an ad hoc gear press. steel plate with hole in the center to fit over one end of the ram, 4 holes in the corner for tie bars. Steel plate same the first except a threaded hole in the center. Make the tie bars out of ready rod. Apply force to the ram, Give it a sharp rap now and then.
    Tom
  19. Likes Mud, dcsipo liked this post
  20. #15
    Oct 2014
    Maryland
    2,458
    1756
    1885
    Quote Originally Posted by LKeithR View Post
    be a lot of work...
    It was for a wood lathe, I just want to save it if it is possible.
    dee
    ;-D
  21. #16
    Oct 2014
    Maryland
    2,458
    1756
    1885
    Quote Originally Posted by Mud View Post
    How big is the ram?
    it is not that big the ram is like 1.5" or so I did not measure it, maybe 4" travel. Guys this is a learning experience not much else if I effitup no one will send me a bill for it.
  22. #17
    Oct 2014
    Maryland
    2,458
    1756
    1885
    Quote Originally Posted by Tyrone Shoelaces View Post
    Regards Tyrone.
    I'll take a few shots tomorrow.
  23. #18
    Jul 2005
    Cottage Grove, MN 55016
    7,590
    4093
    4537
    Are you in a BIG hurry? If it's a wood lathe I suspect it is a thin casting and will probably crack if forced in a press. If your in no rush, looks at a post from , forgot his name, but he hosted the class I had in the UK a few years ago....he had a hydraulic press with a rusted piston in a cylinder and he soaked it in citric acid water mix for a few months and as he said that mixture eats away rust and it worked. Keith Rucker also did one on You Tube where he uses a battery charger. Melcom is his first name of the uk guy. Look back a few months on here and we talked this same issue. I had a distributor stuck in a engine block years ago and a Ford (fishing buddy) mechanic told me to squirt it with PT Buster and tap on the shaft for 5 min each day for 2weeks....I did and it worked....as the other guy said the vibration worked in the liquid. I would not try pressing it out now or yu will be ask us how to weld up a tailstock next. Or to embarrassed to ask.
  24. Likes dcsipo liked this post
  25. #19
    Oct 2014
    Maryland
    2,458
    1756
    1885
    Quote Originally Posted by Richard King View Post
    ....... Or to embarrassed to ask.
    Hey, that will never happen. I ask questions no matter what. But I like the dips in your stores of wisdom. I will leave the Buster in it bang on it see what happen.
    dee
    ;-D
  26. #20
    Oct 2014
    Maryland
    2,458
    1756
    1885
    dee
    ;-D
  27. Likes 4GSR, Lurk liked this post
