key "stuck" in shaft
Results 1 to 18 of 18
    Dec 2018
    New Jersey
    Default key "stuck" in shaft
    This is the driveshaft from my Delta bandsaw. I'm trying to replace the bearing, but this key appears to be stuck. I tried tapping it with a small chisel but it only moved a little bit. I also tried grabbing it with vice grips but that didn't help, either. I don't want to mess up the shaft or the key if I can help it. I can't drive the bearing off in the other direction because there's a shoulder behind it. Any ideas?20210516_115002.jpg
    Apr 2004
    Idaho
    209
    5
    36
    Do you have a milling vise with smooth jaws? If you do clamp the key in the vise and see if that will give you enough purchase to get it out. If not use side cutters to grab one end and lever it out. You will have to dress the key up with a file after the side cutter trick, but it usually works, especially if you already got it to move with a hammer and punch.
    -Brian
    Sent from my SM-N976U using Tapatalk
  3. Likes awander liked this post
    Mar 2009
    Eureka, CA
    4,364
    1016
    1746
    As Brian noted, sharp side-cutters and some leverage will get that little sucker out, pronto. You'll have to hold your mouth just right for that procedure to work though!
    Stuart
    Jul 2008
    Philadelphia
    2,141
    590
    492
    Might try a small amount of heat to the shaft prior to the other suggestions.
    Just a tad bit mind you.
    Sep 2009
    Phoenix,AZ
    2,054
    3255
    553
    Hit key with a small blunt punch 90* to the shaft at one end of the key. That is probably a Woodruf key rather than a square key. Woodruf keys have a rounded bottom and doing it this tends to cause the key to rotate out of it's seat. they can be a bitch!!
  7. Likes ballen, Tyrone Shoelaces liked this post
  8. #6
    Oct 2009
    Olympia, Wa
    772
    336
    242
    I have had a woodruff key that was so tight I could not get it to budge with heat, or anything else I tried. In the end I just filed the key off smooth, took the shaft out and recut a woodruff key slot
  9. #7
    Aug 2012
    Lower Thumb, Michigan
    268
    67
    192
    It appears to be a woodruff key, so one solution is to use a brass or aluminum drift to drive one end down into the shaft so it will roll itself out.
    If you get lucky....
    Mike
    ..like John said! I type slow.
  10. #8
    Jun 2013
    428
    348
    182
    Quote Originally Posted by bpress54 View Post
    ...I don't want to mess up the shaft or the key if I can help it...
    The key is expendable. If you hammer it down, against the shaft, it could make the fit even tighter. Instead, drift it towards the bearing until it is exposed enough to get a good grip on it.
  11. Likes eKretz liked this post
  12. #9
    Jan 2007
    Flushing/Flint, Michigan
    10,435
    603
    8469
    Protect the threads with electrical tape and go after one end with a single sided chisel from the end.
    There is also the weld a helper or lever on top method and hit that with a big hammer.
    I you do know it woodruff tapping (banging) down one end sometimes gets it to rock and the higher end will then more like a chisel.
    Worse case is drilling holes in it. This allows the sides to collapse with some persuasion. This IMO last resort as a whole lot of work and nailing all in position hard to do. (start small, work up}
    It is a piece of silly metal arguing in a machine shop, eventually it will lose the battle.
    If using vise grips which is great make sure they are new or grind the ends as not much to grab here.
    Most my vise grips have rather poopy ends or tips from abuse.
    Here not pull out force applied which will never work a but twist or in reality hammer the vise grips sideways (lengthwise) tilting the key.
    More insane is die grinder or cutoff wheel taking out most of the mass but not hurting the shaft.
    I'm sure I have only touched the so many ways in a metal cutting or fab shop.
    And then there is heat...
    Think of it as not problem but a challenge and the joy of winning.
    Bob
  13. Likes JohnEvans liked this post
  14. #10
    Jul 2005
    Cottage Grove, MN 55016
    8,386
    4402
    4919
    It looks buggered up. file the burrs.
    Woodruff key removal method. - YouTube
  15. #11
    Apr 2006
    Manchester, England
    9,200
    1514
    6146
    It certainly looks like a Woodruff key going off that photo. Like some others have said my technique was to wallop one end of the key with a hammer and a brass drift. That usually brought enough of the other end of the key out for you to grip it in a vice to remove it. I’d ground the jaws of my vice smooth so I could grip stuff like keys without damaging them.
    Regards Tyrone.
  16. #12
    Nov 2012
    Connecticut
    165
    5
    34
    I repaired a small pump that had a tiny woodruff key in it. I don’t think the shaft was 1/2”, maybe 3/8”, in diameter. The key was worn half way thru. None of the methods mentioned above worked for me. I ended up tig welding a piece of scrap to the key and driving a chisel between the shaft and the scrap. The key came out with little effort, and the replacement when back in just fine!
  17. #13
    Aug 2014
    lennox, sd, USA
    234
    91
    230
    Another method is to drill through the key until you hit base metal and bottom tap the hole as close to the bottom as possible. Then drop in a loose ball bearing and use a bolt to crank it on out. You can also hand grind or turn the threads off the bottom of the bolt to give it more travel.
  18. Likes Richard King liked this post
  19. #14
    Mar 2005
    Kansas
    8,565
    590
    4308
    IMO the aspect ratio is wrong for that to be a standard Woodruff key. It may be an extended Woodruff where the ends are straight and overhang each end of the keyseat. In this instance hammering will distort the shaft raise your ire.
    I would weld a lever to the key, and pry the lever up. If your welding equipment isn't up to the task, my next choice would be to take a size narrower woodruff cutter and cut out the center.
  20. Likes ratbldr427 liked this post
  21. #15
    Dec 2020
    45
    51
    6
    If all else fails Another way is to drill it then tap it and use a slide hammer to pull it out.
  22. Likes doug8cat liked this post
  23. #16
    Jul 2019
    Illinois
    45
    75
    33
    Quote Originally Posted by ironsmith89 View Post
    I had one on a BP ball screw that would not come out even with this method, pulled the threads right out.
    I ended up removed the ball screw, put it in another BP, took a narrower keyseat cutter, and went right through the middle, relieving enough side tension that the old key came right out. Wish I would have took a pic of it, but highly recommend it.
  24. #17
    Jul 2008
    Philadelphia
    2,141
    590
    492
    An analog to drill tap slap hammer. Tig a bolt to it and giver WHA with the slide hammer.
  25. #18
    Sep 2002
    Lawrenceville GA USA
    6,364
    945
    1454
    As this thread is not really in line with what this forum is for I will be locking it. Also I think we have exhausted most of the good ideas for removing a key. Thanks to all who contributed.
    Charles
