On top of the one double V is a flat area about 1/4" on some and 1/2 on bigger ones. They ground that at the same set up when they ground the V's so set the ball ring or ball on there. Then if you want to see how much wear is in the bed you can clamp on a indicator on the ball shaft and indicator on the ways and move it. Also if the lathe is assembles set the level on the saddle wings and use the saddle as a Kingway and crank saddle down the bed. Head stock end under removed chuck and the farthest to the right TS end. Vintage Machinery has a description on the last book reprint on their list last time I looked. :-) For those who don't know, Glen is one hell of a good scraper...he also had a good teacher :-) Rich
