What a coincidence! I also give free advice to others and not just here. Many know I am the international BIAX Instructor and teach scraping all over the world.
I just got a help request from BIAX Germany on how to scrape bronze bushings inside a power plant on a line shaft in Poland. They have 2 bushings that were replaced and are approx. 18" diameter and has caps too. The method the worker in Johns show is doing it the way I was taught when I was a kid using a spoon scraper. On Big Bushings I scrape today below is how I do it. I still use a spoon scraper and a small hook scraper for doing on smaller bushings say under 6". The bushing he shows looks as if the oiling system stopped working and heated up and scored. The black spot on the back was a hot spot. The galling or circular lines is much like the scores we see on flat ways that are created from lack of lube at first and then metal that breaks out.
An:
Cc: @biax.de>
Betreff: scraping of rounded inner surfaces - request for advice
I do not have much experience in scraping rounded inner surfaces as enclosed. (I left out the photos and changed the names a bit for confidentially of this. rk)
Is it possible to use our scrapers for such operations?
maybe, very narrow blades/plates are to be applied (max. 10 mm), with small radius max. 60mm? HM or HSS?
Our BL scrapers or hand scrapers?
Material to be scraped: bronze:
Von:
[email protected] [mailto:
[email protected]]
Gesendet: Freitag, 17. August 2018 16:12
An:
Cc: Alex King
Betreff: RE: WG: scraping of rounded inner surfaces - request for advice
what I wrote back:
From R. King
I would recommend the start using a BIAX Handscraper with a 1/2 moon flaker insert. R60 using the blade holder (s) KL-70 or KL140. Once they practice the checkerboard technique and understand how the blade works. They can use a BIAX Power scraper with a KL-170 extension holder. Tell then to start with a 9.5 to 12.7 (3/8 to 1/2") with a very slow motor setting.
They will attack the bushing from the 45 degree angle similar to the hands scraping technique I teach. They may have to design and use a blade holder with more depth to the bend and experiment with sizes.
Another important part when scraping big bushings (bronze bearings) is to examine the wear pattern of the old bushing. The shaft will have pressure or torque on certain sides or direction and those areas will wear more. Once they establish this they will remove more material in the NON wear places in 3 places so the shaft is setting on 3 points. The low areas will also be an internal reservoir for lubrication oil that will flow around the shaft. With a bushing that size I would think the 3 point pads would be approx 6" each of the radius of the circumference. They can do the math. (ha ha)
The BIAX 1/2 moon blade is ideal for scraping BIG Bushings like this, but takes a little practice to understand how to. The blades 60 mm bottom radius allows them to scrape in the center of the blade. If they use a blade like a 20-150 blade with a flat blade the blade will cut on the outside edges.
There is another option and it is called Timesavers Lapping compound. It was designed for the USA Navy so sailors could fit propeller shafts on large ships.
http://www.lappingcompound.co.uk/Timesaver Lapping Compound Booklet-4.pdf or
http://www.newmantools.com/lapping/timesaver_booklet.pdf
After using the Timesavers you would still need to cut the bushing with the checkerboard pattern and make the 3 pads.
Tell them If it is an emergency my team could come and help them.
I hope this helps.
Rich
