I'm trying to rebuild an old Fanuc tape drill.
The machining performance was terrible so I assumed it was the spindle taper which was in really bad condition.
The spindle has been reground and the runout on the tool taper (DA180) is less than .0005”, but it still can’t side mill to an acceptable finish unless it is going very slowly.
I can see there are tool deflection issues. It leaves a vertical line on the side if you stop mid cut and leave the spindle running. The tool deflection could be caused by lots of things and I’m trying to narrow it down.
I need to determine if the tool deflection is in the spindle bearings, the linear ways, or backlash in the ball screws. It is probably in all three, but what is the worst.
Has anyone got some test procedures I could follow to narrow down the cause?
