Machining a straight edge - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21
    Jun 2008
    Bellingham, WA
    4,099
    987
    2234
    I mentioned the other day that I was not happy with the method I used to scan the sole of my 18" SE. So I made a better "surface gage" using a Mahr tenths-reading electronic indicaror and a 4" diameter steel puck that weighs about 6 pounds. I added a .400" diameter annularly relieved shoe to the indicator tip so that the tip rode smoothly over the shallow grooves made by the face mill.
    Here is a video showing the plunger shoe or puck. I made it out of O1 tool steel and hardened it prior to brief lapping.
    And here are a couple of stills.
    Here are a couple photos of the holder or gage base prior to assembly
    I figure this tool will come in handy as it will make scanning my machined straight edges prior to shipping a lot more convenient.
    Denis
  2. Likes TGTool, JHOLLAND1 liked this post
  3. #22
    Dec 2015
    Connecticut
    1,097
    26
    361
    That’s pretty slick.
    Is that my 18? Did you scan the whole bottom? Is it really within a tenth over the whole bottom? Indicator working?
  4. #23
    Jun 2008
    Bellingham, WA
    4,099
    987
    2234
    Yes, that is your SE. I cannot easily check the entire sole as I have to suspend it on 2-4-6 blocks. The indicator is working and does repeat accurately. I would not claim a tenth over the entire sole. My initial purpose was to show flatness to .001 or so. Looks like it is much better than that and certainly “good enough.”
    The vial came from Geier and Bluhm. So, I will install it and send the SE on its way.
    Denis
  5. #24
    Dec 2015
    Connecticut
    1,097
    26
    361
    Awesome!, I’m in need of it
    Thanks for the quick turnaround
  6. #25
    Jun 2008
    Bellingham, WA
    4,099
    987
    2234
    Boxed up. It will go to the post office Monday morning and will ship USPS
  7. Likes Paolo_MD, JHOLLAND1, rimcanyon liked this post
  8. #26
    Dec 2015
    Connecticut
    1,097
    26
    361
    The 18” arrived today,
    I am very pleased with everything-the overall design, how it feels and handles, and also the workmanship.
    The casting looks extremely nice, with no voids and even the smallest details in the font for your name and the date.
    Your bullet proof packing was appreciated also.
    Looking forward to the 36” and getting to scraping and painting to make them both perfect.
    Thank you very much.
  9. Likes dgfoster liked this post
  10. #27
    Jun 2008
    Bellingham, WA
    4,099
    987
    2234
    Just a note on a new way I am making the little 5/32 hex crooked wrench:
    Yesterday I was finishing the machining of an 18 I am shipping to Brooklyn today.
    Until now I have been either tigging or silver soldering that little bit of hex into the arm of the steel bar to make the wrench. And I had been simply bending the crook into the bar by eyeball. That made a serviceable wrench, but I did not like its appearance. The tool is necessary to tighten the mount screw located at the rear of the vial mount and housing since there is little clearance above the vial and housing and only a fairly narrow space between the tube and base of the vial housing.
    So yesterday I made a simple (some might say crude <smile>) die to put the crook in the bar and I made a hardened O-1 anvil and hollow punch to swage the bit into the bar. The result is a nicer looking and better functioning tool. In addition to improved form and function the two new tools allow the tool to be made much more quickly and conveniently. A single light smack of a 2 pound hammer does a nice job of swaging and bending the bar with the dies is done with just a good squeeze in my Kurt vise.
    Here is the punch and anvil in position to swage the hex bit.
    The punch and anvil
    Reaching under the tube to get at the rear mount screw
    Top view of same
    Bending die and bent blank.
    A few more pics in the next post.
    Denis
  11. #28
    Jun 2008
    Bellingham, WA
    4,099
    987
    2234
    Here are a few more pics
    The swaged hex in the bar.
    I could not stand the appearance of the anvil. So I ground its face.
    The anvil base is relieved to help it rest securely on the backup plate---no tendency to rock.
    Denis
  12. Likes TGTool liked this post
