Hey Cal,
Your happy with yours it sounds which is great! I was hoping it would end up being a nice solid lathe. Its a big step up from my previous south bend 9 haha. I just checked the bed, mine is marked 7164, from my guessing it was early 70's.
You wouldn't by any chance know much about the spindle brake on yours would you? Mine has no means of stopping the spindle short of plugging reverse. I will be running mine on a vfd so my braking will be limited to dynamic and dc injection, and plugging wont be possible. I have scoured as much of the net as I can to find info on the original braking method, and have only been able to find some people referencing a cable brake. What the cable is attached to I have no Idea. My motor has no electromagnetic brake associated with it and there are no mechanical brakes either. Any light you could shed would be appreciated.
Thanks, Jarrad
The original brake system on my lathe was all motor electrical. Nothing mechanical at all. A system based on opening the supply relays and then injecting DC into a pair of motor windings through a resistor with a setable timer. There was a Selenium stack rectifier in the electrical cabinet along with the timer relay and resister coil.
Perhaps you have some legacy of this same network in your cabinet.
It never worked reliably for me, sometimes nothing, and other times there was a pleasant resistance slowing the motor driven spindle. Eventually the resistance coil burned or broke. At least then I could count on the spindle slowly winding down. ;-)
Now I have the machine on a large VFD. What a treat! All connected and controlled by the apron lever. The inching button is even fully functional at a slow jog. There are times when It might be handy to have more than one stop ramp programed. One for slow spindles and rapid stops, and one for slowing down fast spindles with big workpieces. IIRC, the spindle now winds down in 3 seconds, with the energy dumped into a resistance winding boxed up next to the VFD.
The VFD has worked well for me for about 15 years. Before that, the lathe was on a home built RPC that would brown out the neighborhood with every start up ;-)
I don't have the multi-travel stop outfit, but there is the plunger for the kick out on the underside of the apron. The mounting bracket for the actuator hardware is there, but the bar, bar mounts, stops and actuator lever are all missing on mine. Not sure it ever had them.
I don't recall needing the set up much anyway. It does look nice though, and for some repeat work, could come in handy.
