matt_isserstedt
- Dec 15, 2003
- suburbs of Ann Arbor, MI, USA
I've been hoping this forum would open...I have in my shop a 24 x 36 Challenge Machinery cast iron surface plate. It sits on a 4 legged stand actually on the 3 points (I welded flat washers to the frame to better locate the 3 legs), and up to now its basically a storage surface for CNC tools and projects. Its in good condition, with uniform scraping marks like a pro would do...suspect original from Challenge and I have rust protected it fairly well. So I'd be worried about movement of the iron due to stresses, or whatever it went thru in its former life.
I have a lifting bridle and the two steel pivot pegs, so potentially it could be inverted. HOWever, I have it boxed into the shop in a pretty good way...lets just say I'd have to move my VMC at this point to extract the plate from the shop. Its not impossible, but would be a fair amount of work.
So I'm trying to figure out what I should do at this point, to qualify this as a master I could use.
Options for inspection, and possible correction (if needed) are
1. remove from shop, take somewhere else to spot and scrape with a shop crane to go along for support. This would require someone else close willing to let me work there and with a granite plate they trusted me to work with. I haven't met that person yet.
2. hire a plate calibration company to inspect, I suppose I'd have to scrape rather than them lapping it like granite. But that could take a lot of their time depending on how far its out. I don't think reliable contact could be achieved as it would seem like shooting in the dark somewhat.
3. I have a 199Z master level, initial thoughts were to use this tool to take a survey, basically moving it all over and keeping notes of the movements to establish high spots, and possibly spots I should avoid. I also have a 2ft and a 4ft straightedge, one camelback and one dovetailed, which could also be qualified elsewhere more easily. Wondering if there's a combination of level and straight I could use to make any correction if needed without going counter productive.
4...???...
Sorry I don't have any actual numbers or preliminary work to report, yet. My "other plate" meaning my life is full with things for the moment but its been in the back of my head and I was trying to sort out my plan of attack (also waiting for yellow ink to come into stock locally...its on backorder at present)
Thanks in advance for your advice
4...???...
