oil grooves on the saddle cross slide ways??
Results 1 to 9 of 9
    Sep 2002
    Salinas, CA USA
    4,875
    550
    456
    Default oil grooves on the saddle cross slide ways??
    This 10EE has zigzag oil grooves on the saddle ways for the cross slide. Never seen that before. Does it make sense to you? Normally the oil grooves are on the sliding surface, the upper part in this case.
    Parts 10EE for sale in Wisconsin
    Sep 2008
    Canada
    1,722
    673
    691
    Not logical. Should be in the hidden part to avoid get swarf/debris in it.
    L7
    Aug 2005
    Toronto
    5,804
    3919
    4607
    On the 10ee, the apron oil pump pumps oil to the bottom cross slide ways. Most other lathe use a gravity feed from wells up above so it seems a bit off at first. The lines feeding this (under the saddle) are notorious for clogging so check them out carefully
  4. Likes CBlair liked this post
    Jul 2005
    Cottage Grove, MN 55016
    8,623
    4520
    5084
    It may have been a design change to increase the coverage of the way oil. I suspect the cross-slide never never travels past that section of the bed so it isn't exposed to the air. I also suspect the operator side of bottom of the cross-slide has oil groves in it and they never get exposed to the air. Yes those 3/32 Bijur pipes either plugged up or got smashed. I prefer Zig Zag oil groves as they spread the oil over the entire flat way. In the old days they used straight groove that were a disaster because the mating surface didn't wear and made a raised area and once the surface were lapped together the ways never got oil outside the groove and scored up. That was a nice feather (kidding)...straight oil grooves made the machines wear faster and they needed to hire me to fix it.....lol
    Aug 2017
    Ohio
    189
    54
    13
    Quote Originally Posted by Richard King View Post
    My Colchester Master, which I think is a 70's or 80's vintage, has a straight oil groove in the cross slide way and an oil pump for the carriage and cross slide travel. The straight oil groove doesn't get exposed, but it has predictably worn a groove in the mating piece. I really thought someone like Colchester wouldn't have taken a shortcut like that.
  7. Likes Richard King liked this post
  8. #6
    Sep 2002
    Salinas, CA USA
    4,875
    550
    456
    My 59 10EE was rebuilt at some point at one of the US Gov'ts rebuild facilities. The saddle was replaced with one that had the straight groove. When I got the machine the bed had worn with a raised area where the oil groove was. I put a replacement bed on it with a saddle with zig zag grooves.
  9. #7
    Feb 2016
    2,367
    1645
    1017
    My 1962 10ee, which is line to be rebuilt, has a single groove on both the saddle and the cross slide ways.
    As a repair, or upgrade, wondering if that single groove can be crossed with a few other grooves along its length. Like crossing a T.
  10. #8
    Jul 2005
    8,623
    4520
    5084
    I prefer zig zag in the middle and the T on the ends about 1" from the ends. Have to make sure the new grooves don't run off into open air, is about it. Be sure to check to see if those small copper lines are clear and if you haven't replace the small metering units. The BiJur pump is inside the apron right? What's it's status?
  11. #9
    Feb 2016
    2,367
    1645
    1017
    I'd prefer zig zag as well, but what do you do, fill it in, then cut a zig zag ? Or cut crosses into existing single straight line.
    This is not my thread, but I will surely address oil system. In the middle of a Monarch Series 61 rebuild now, probably start the 10ee sometime after the 1st of the year. However on both lathes, I'll be separating carriage from apron's oil system.
    One shot or hand pump for carriage and cross slide. Apron self contained using its oil pump.
