Q: Technique or tool for spreading blue on a dovetail
Results 1 to 20 of 20
    Oct 2010
    Oregon
    5,818
    5792
    2249
    Default Q: Technique or tool for spreading blue on a dovetail
    I've been working over the Y axis of an unmentionable, got the load-bearing bed ways and saddle ways planar, and used a dovetail straightedge to clean up the non-gib dovetail of the saddle. I now want to blue up that saddle dovetail to transfer to the mating bed dovetail in order to check/correct the mating dovetail angle, and I haven't had to do that before.
    How do I get a reasonably even coat of blue in that space? Obviously the roller/brayer will not fit. I've been thinking about a small cloth pad wrapped around the end of a tongue depressor ("craft stick"), but surely there's a better way...
    Jul 2006
    Hillsboro, New Hampshire
    14,149
    3095
    9383
    A section of (say) 1/4" rubber sheet cut to the correct angle, and used like a squeegee? You could even comp the angle for the deflection under use.
    Aug 2017
    359
    99
    176
    I use a small paint brush.
    Jun 2001
    St Louis
    19,568
    2486
    3757
    Your pad on a tongue depressor (or similar) is likely the best plan. Make sure it can get to the back of the dovetail and coats well there.
    I've never used a roller but a couple times, and didn't like it even for flat open surfaces. So I use a pad all the time. Should work fine.
    Some will cringe and have many reasons why it's bad, but I use the blue paper shop towels, rolled up, doubled over, with the loose ends stuffed into a piece of tubing. For dovetails, same stuff, but wrapped on a flat piece of "something". Tongue depressors are thin and should be fine for reaching into the dovetail. You might need something thinner to reach to the back, though.
    With the "pad" approach, it takes a bit more blue because some goes into the pad. I think the coating is better than with the roller, and the pads I use tend to pick up and remove any bits that get stuck in the blue.
    Those shop towels have the fibers bonded so they do not drop loose fibers unless really shredded.
    Sep 2006
    Stillwater, Oklahoma
    1,896
    150
    1126
    This guy uses pad applicators and makes small ones for dovetails.
    Jun 2012
    Michigan
    14,247
    4854
    5137
    Sep 2008
    Canada
    1,720
    673
    686
    I make a wooden wedge and glue thin layer of rubber on it.
    Seems rare tho. Most of the time I’m spotting a dovetail from a blued straight edge.
    L7
    Sep 2006
    1,896
    150
    1126
    Quote Originally Posted by lucky7 View Post
    L7
    The OP's situation is one case where the question is completely pertinent. He will have scraped the saddle dovetail on the headstock side so that it is flat (tested with the dovetail straightedge) and transverse to the ways with that slight allowance for concave turning. The precise angle of the saddle dovetail may have changed slightly but it's not relevant.
    Now the crosslide will be scraped to match the saddle and its dovetail now becomes the master - at least for the correct angle. He may be doing an occasional crosscheck with the straightedge depending on the relative lengths of the saddle and crosslide surfaces. It would be possible to get the inside vertical dovetail of the crosslide casting slightly convex if he's not careful.
  9. Likes JST liked this post
  10. #9
    Jul 2005
    Cottage Grove, MN 55016
    8,577
    4499
    5048
    Back in the old rebuilding all the time I looked in the closet and pulled out an old work boot and cut up some leather. I've used leather belts. I've also used the corner of a red rag. If you cut off 3/4 of the bristles on a paint brush that works too, but occasionally a bristle comes off. A secret to dovetail scraping is to cut the bottom vertex. That lets you get down there deep and less likely to leave little high spots. I like the leather on wood block idea Lucky suggests.
  11. Likes JST, sfriedberg liked this post
  12. #10
    Jun 2001
    St Louis
    19,568
    2486
    3757
    If you do not recut that vertex with some clearance, you may find that the "point" of the mating part is riding on it.
    That's especially true if you had to take off a fair bit of material when scraping it.
    The other problem there is that you may (at least I seem to) find that a curved surface has developed back in the corner on one of the two surfaces, and unless there is some better clearance, you'll play heck getting rid of it.
    I've had to use a wedge-shaped piece of HSS, that looks sort of like a cutter for small acme threads, to cut down the curved surface so that it can be scraped normally. That's after re-cutting a clearance.
  13. #11
    Oct 2010
    Oregon
    5,818
    5792
    2249
    Quote Originally Posted by JST View Post
    Yep. On this particular machine, the points have been chamfered/clipped a bit so they won't ride. However there is no relief groove on the female inside corner and the Biax tips can't get all the way in there.
    I ground out an adequate groove so I could ensure the remaining surface is actually flat. The other side doesn't have this issue because the gib occupies the corner space. If I were doing this again, I would just enlarge the existing chamfer to ensure any "can't get in there" falls into the void.
  14. #12
    Apr 2013
    Damascus, MD
    1,712
    5035
    976
    I generally use a piece of Shammy backed with a piece of wood, or something similar.
    Before scraping the female side of the dovetail I cut a relieve with a slitting saw, in the case the piece has been machined, or with a large power-hacksaw blade.
    Paolo
  15. #13
    Mar 2002
    dallas,tx
    2,736
    790
    590
    Thick, hard felt cut at an angle works well for me.
  16. Likes Richard King liked this post
  17. #14
    Jan 2006
    Brookfield, Wisconsin
    4,466
    338
    493
    Has anyone used an airbrush ?
    If not, what is the reason?
  18. #15
    Mar 2007
    Wisconsin
    528
    370
    248
    Quote Originally Posted by Spud View Post
    This is by far the weirdest question you have asked on this forum, bluing is paste. Have you ever set up an airbrush to apply mayo to your ham sandwich before school? If you have not what is your reason for not doing so?
    Scraping is hard physical and mental work, there is no time to make love with an airbrush. I found a thick piece of felt to work or just a corner of a rag or what ever I can find in the 5 seconds I have to find something.
    Digger doug's attitude is starting to rub off on me LOL
  19. Likes sfriedberg liked this post
  20. #16
    Jan 2006
    4,466
    338
    493
    Quote Originally Posted by MCritchley View Post
    I used dykem for about 1 semester in a machining program; it was not paste like, it was free flowing liquid that would drip easily. If it was thinned a little more, would it work just as well ? At the college autobody program, I used an airbrush to do some touch-ups; it didn't seem slow compared to a thin paintbrush.
  21. #17
    Sep 2006
    1,896
    150
    1126
    I think you're confusing layout fluid with marking compound. Time to expand your knowledge.
    Do you remember the movie, The Jerk with Steve Martin? He never realized he was adopted, even though he was the only white kid in a black family so you know where he was starting from. As he's heading off into the big world his dad is giving him some advice. That is, knowing the difference between a tin of shoe shine compound and something the same color that's found randomly in nature.
  22. #18
    Jun 2001
    St Louis
    19,568
    2486
    3757
    Dunno, maybe you could thin the Dykem to spray it, but I have no idea why that would be good. I suppose on second thought that you could maybe get a thin coat if diluted, but............... NAW........
    I'll keep using the "pad" method so I know where I'm putting the stuff. I'd get blue enough on the outside, I don't want to get blue on the inside when I breathe in a fog of solvent and blue...... I could really be "singing the blues" if I did......
  23. Likes CBlair liked this post
  24. #19
    Jan 2006
    4,466
    338
    493
    Quote Originally Posted by TGTool View Post
    The T.S. said "blue" so I presumed he meant something like Dykem, but now that I think about I realize I was mistaken.
  25. #20
    Oct 2010
    Oregon
    5,818
    5792
    2249
    Yes, I meant die spotting or marking compound (Canode, or Prussian Blue in grease), not layout die or colored shellac. Dykem makes both hi-spot blue and layout blue, so the brand name alone won't tell ya.
