Speed-Racer
- Sep 9, 2021
I purchased a seized Quincy 325 pump from the original owner, randomly found the ad. Said it would not turn on one day, it has lived in an outbuilding next to a wood working shop/barn. He purchased a new pump and did not want to throw it in the recycle.
Could not get the flywheel to turn at all. Thought it may be a parts machine or repairable, but I have wanted one of these for a while. This line of pumps were way way outside my budget when I purchased my QT5 years ago.
Funny, most of the semi local shops I called pushed the new random brand pump they are currently selling, saying it would cost less.
I have found some excellent YouTube videos from Rotarycomptech, just outstanding work and stumbled across his videos years ago and this likely gave me the courage to give this project a go.
Also some more recent content from a compressor shop channel called The Compressor Guru. Nice rebuild series on an IR, the 325 series were rushed and I hope another 325 rebuild makes the channel. The practical machinist and GJ have good threads, but many details are missing. A lot of content is a fresh beautiful coat of paint, but I need to go further (plus paint).
Will share some pictures of the partial disassembled 40+ yr old pump. I think this one is starting to look rebuildable, but needs a lot of inspections, cleaning and new parts.
Would normally use only OEM parts especially since the original parts have lasted so long. One of the rebuild threads showed factory OEM parts with overseas sourced bearings vs the Timken USA made bearings.
Would like to rebuild so it last longer before the next rebuild.
So I need help with who currently makes the really good parts for a 900 rpm pump, many of the good companies of yesterday have sold and the parts are relabeled using global components. But are the parts still a premium line or not so great. Just because it says made in the USA, if current quality is horrible it should be avoided.
Piston rings, rod bearings, wrist pin bronze sleeves and other small pieces, such as the crank seal. I will track down some new or nos timken USA bearing if they are needed, those are good stuff imo.(car projects+), also, the org ones seem to spin really nice so maybe leave alone if they check out.
Would appreciate tips on how to rebuild this better than when it was first manufactured and keep me from messing up.
You can see lots of carbon, wonder what caused this or due to an extended period of no cleaning? Could not remove one of the 3/8 hex thread locks, actually split my 3/8 socket in half. Hoping a long soak in pb blaster and heat will free it.
