Have a Fosdick 3’ arm sensitive radial drill press. Previous owner torqued the heck out of his hold down bolts and the area near some of the slots are as much as ten to fifteen thou raised. Enough that I can’t slide stuff across table without catching. Will scrape it down. I’ll likely stop once blue starts spreading out from raised area and call it good enough, but will also measure from spindle. If I get fussy, should I be shooting for half a thou high per foot at free end of table, or 0/0?
For those that haven’t seen this kind of drill, it’s also designed for boring, not just rough drilling. Whether I’ll ever use it for boring is another question...
L7
L7
