Turbine Builder
- Oct 2, 2016
- Melbourne
Thanks Tyrone,
I found putting the mill in the corner use up the empty space, and looking at the mill front on i can cut a hole in the plaster wall if i had to As that side of the garage was block of for a small storage area.
Cheers,
Mark.
Turbine,
Tell me a little more about the X-axis table movement mechanism. I'm accustomed to a leadscrew anchored to the table with a nut fixed to the saddle. Rambaudi is doing something, clearly heavy duty, but doesn't look anything like I'm used to. I see thrust bearings, possible backlash compensation and other recognizable components but I can't put them together in my head.
I have worked on several of these machines
The feedmechanisme is not a worm
Normaly you have a long spindle and short nut
This is just the other way around A long 180dgr nut and a 2 piece short spindle
With the 2piece spindle you can adjust backlash
This enables you to have the handwheel on the front in handreach
Peter
A worm to me means a gear profile
But if you want to call it a worm thats fine with me
Peter
Notice
