The motor shaft on mine was damaged so I thought it would be a fun exercise to replace it. Ordered the part and new bearings, watched H&W's video on teardown and I've disassembled my motor successfully. I am a little fuzzy on the reassembly. Should I press the bearings into the housings and press the housings onto the shaft? Should I heat the bearings using a bearing heater and plate them on the shaft, then press them into the housings?
Also, should I put some grease on the bearings before pressing them in? Such as Dart CMD Extreme Pressure Lubricant.
