Reconditioning a shaper - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 21 of 21
  1. #21
    Virginia
    24,168
    7561
    7487
    Quote Originally Posted by rj1939 View Post
    Still raining, so I took another look at my situation and did some more measuring. I'm going to grind the .010 step back flat on the gib side. The bronze filler strips under the hardened top straps seems like the most practical approach......easier to machine and would easily allow for future adjustments.
    Did a little scraping...........ATW castings seem like they are going to put up quite a fight.
    If the "space" those filler strips fit into is parallel, there might be NO machining at all, just sharp shears and de-burr. Bronze shim - also Stainless Steel - can be had in most any thickness, is usually "stackable", otherwise "peelable" in removable layers to come DOWN to a thickness.
    Have a look. See if either of those could suit a place of this sort.
    MMC has it. They are not alone.
