durableoreo
- Jun 5, 2020
Purchased a small horizontal mill recently. It's labeled "A V Carrol" and . I'm getting it ready to make chips. It was fairly cheap but it came with quite a few issues, including lever-feed on the x- and z-axis. There's still flaking on the ways, which is nice to see.
Trying to get the arbor off. Partly to figure out how it all goes together, partly because I want to make another arbor for 1-1/4 cutters.
It LOOKS like the arbor goes straight through and there's a round-belt pulley on the back---or a hand wheel. The center part of the arbor goes through the diameter of the, er, headstock? The arbor has a groove for a set screw, which transmits the torque from the internal belts and pulleys to the arbor.
I took off the hand wheel, a brass spacer, and removed the set screw. The arbor mostly turns freely but binds in 1 spot. I suspect someone removed the original extended-tip set screw and replaced it with something that raised a burr on the edge of the arbor's groove.
There's about 1/8 axial movement but it stops sharply in either direction. Can't figure out what's holding it.
Any ideas?
Here's the whole mill. It's one of those small single-operation type mills for small parts, so the table is about counter height.
Here's both sides views of the spindle.
Closer view of the working end of the arbor. Note the keyway is not lined up with the set screw hole because I was messing with it. And you can see that the screw has a conical end, rather than cylindrical. The bearing is mounted in this little cylindrical mount/enclosure. It's a tapered roller bearing that's tensioned from the back, so the bearing assembly is sealed by that cover but the cover is held on with t-slot nuts---the screws sticking out aren't studs going back to the main casting. The bearing enclosure bears against the main casting but is not connected with fasteners.
Closer view of back end of arbor. The arbor has some damage from the set screw but it's a fairly thin-walled tube at this point so it's more of a dent, no burrs that I could feel with a stone. The handwheel came off without trouble.
Looks like they scabbed on a bit of tubing. I think the brass spacer was catching on the edge. On the right side, you can see the driven axis, which is a threaded tube. There's a tapered roller bearing in there and the big lump there (first 2 steps) is a retaining/tensioning nut with fairly fine threads with a heavy bushing (3rd step) that transfers compression from the nut to the inner cone of the bearing . When I removed all those parts, the arbor still wouldn't come out.
These last 2 images are my attempt to show the play in the shaft. It rotates more than is shown here. But the end play pictured is the extents if what I'm seeing here.
Here are images of the make/model. I haven't been able to find information about anything other than lathes that were produced by A V Carroll. I could have sworn there was another thread I started back when I was in rigging mode... Anyway, someone pointed out that machinery companies sometimes re-sell models that they don't directly produce, for business reasons. I noticed that the base is fairly generic and the only other place the manufacturer's name appears is a removable cover---easy to re-brand. So if anyone recognizes the castings, I'd be glad to know more about the manufacturer
Any ideas?
