Hello all. 1st post and found this forum after searching for advice on how to proceed with a woodworking machine restoration/rebuild, specifically resurfacing the tables and possibly the lower wedge ways of an old American 16" jointer (pre Yates-American). Best guess was 1911 as the year of manufacture.
Problems:
1) Tables are too out-of-flat. Infeed and Outfeed tables have a lengthwise wallow of .015 and .010 respectively, in the areas just before and just after the cutterhead (already had a new Hermance Helixhead made and installed). These problem areas extend about 12 inches away from the cutterhead, gradually getting better to a relatively flat area in the center of the tables. These areas are consistent with where most of the pressure would have been applied over the decades.
2) The entire lower wedges (infeed and outfeed) rock on their flat ways against the angled base; neither mate properly. Neither the infeed nor outfeed tables are stable without shims or over-cranking on the gibb screws. It's currently not possible to align either the infeed or outfeed table.
Potential Solutions:
1) I've found a company that does metal planing in my area (tables were originally planed...you can still see the old scalp lines on the outfeed table..see pic). They want about $1200.00 to plane both tables, and another $900.00 to plane the undersides of the tables (see pics) if I want that done. Not sure if I want the undersides redone or if I should just shim them...? Found another company Schaffer Grinding that would do both tables, just the tops, for $900.00...not sure if their quote was for surface/mattison grinding or blanchard grinding, will follow-up
2) Not sure if I should just attempt to shim the ways for the lower wedges or try and have those redone as well. Got a good amount of $ invested so far, and I'm curious as to HOW these jointers were originally machined...and how similar jointers today are machined. This style of jointer has tabletops that rest on upper mating/sliding surfaces of a lower wedge, which then mates with the angled base with flat ways. I'm thinking they used some sort of fixture to machine the upper and lower surfaces of each lower wedge, but the jointer base itself had to be machined as-it-stood, with its mating surfaces for the wedges at a near-45-degree angle to the floor.
Question:
What do you all think of those resurfacing quotes? I'm going with something, just don't know which. Getting more quotes next week. Leaning toward planing...
Assuming it can be done accurately to maintain alignment, would you shim or resurface the ways (both the lower wedge ways on the bottom and the jointer base itself)? And how do you think they were machined in the first place? How would a shop resurface them accurately? What machines, what methods?
I've attached an initial set of pictures; will attach more tomorrow.
Thanks for reading, and thanks for your time!
-Devin
Central CA
Problems:
Question:
-Devin
Central CA
