Rivett-608 Repair
Likes Likes:  0
Results 1 to 5 of 5
    May 2020
    Ohio
    Default Rivett-608 Repair
    I stumbled upon an inexpensive Rivett 608 lathe over the weekend and I am in the midst of researching how to get it running again. As the username suggests, I am entirely clueless about this process but I am excited to learn and would welcome any advice.
    A little about the lathe:
    Rivett 608-PC-5C
    Made 1942
    Everything moves, but some parts more freely than others
    Some superficial rust on drums and casing, no visible pitting
    Thick coat of congealed oil on the ways and gears
    Sits on a cast iron drip pan with speed box motor drive, like below
    Came with a motor, but the wiring was disconnected and there is no name plate. It has four wires, so I think it may be a 3 phase motor? One white, two black, and one red wire.
    My main question is what the proper type and length of belt would be to connect the speed drive to the headstock, but any tips would be appreciated. I am also interested in recommendations for oil to keep everything running smoothly once I have finished.
    Jul 2005
    Cottage Grove, MN 55016
    7,861
    4203
    4674
    I looked on Vintagemachinery.org and here is one booklet. Most lathe built by the same Mfg. are close in design. I did not look though the all of the booklets. Rivett Lathe Mfg. Co. - Publication Reprints - History of Rivett Lathes | VintageMachinery.org
    Jun 2001
    St Louis
    18,414
    2040
    3216
    Hopefully yours is better than the one I bought a while back. It's almost all there, but many parts were found in the drawers, mixed with dog kibble and irrelevant lathe parts from other machines. I have refurbished and re-scraped some of it, but the next big part is the bed, which I now have the reference tools to do. I have a mill to finish first, and then I will have time to start on it.
    As first seen in the advertisement.... Apparently he had a flip phone.... the seller built drag racing rails, he was a welder, not a machinist. Odd thing is I called about it the first time it was for sale, but I guess he knew the seller then (another drag racing fabricator) and bought it. He turned it on by plugging it in, and had taken off most of the parts, but at least he oiled it.
    parts and kibble....
    QC as received
    The bull gear had a few issues
    May 2020
    Ohio
    Luckily mine seems to have no teeth missing on the gears. It seems to generally be in good shape, just a lot of very old grease. I'm having an interesting issue with the gearbox. I have taken it off and have a bit of an issue with the pins that connect it to the powerfeed leadscrew. I posted about it over here - link. If anyone has any insight, I would greatly appreciate it.
    Oct 2003
    CANADA
    Ontario
    1,226
    100
    126
    there is a lot of Rivett 608 material available here:
    Shaper Book Page
    Manuals and parts lists and some drawings
