If your mounting linear rails...points are not important it is a percentage contact surface. You can scrape to 5 and stone, file or emery cloth it for percent and alignment. If your looking for ,0001" or better you could scrape 20 ppi and then do above. Depending on design and stability It's unlikely I would use aluminum on anything precision.
