Hi,
I’ve seen quite a lot of discussions about restoring hardened ways. The consensus seems to be that you should either use a surface grinder or abbrwsive disc grinder as a last resort (like when a machine can’t be moved).
I was wondering about alternatives and as CBN is used for hard turning I wonder: has anyone tried “hard scraping” with a CBN insert? Assuming you could find one big enough, cause a lot of them seem to have CBN only at a tip of the insert.
