Geir T Simonsen
- Jan 3, 2014
- Norway
The exhaust manifold on one of my cars was warped, about 1 mm high in the middle. Common problem on Land Rover Td5 engines. After cleaning it up on my old VBRP mill it's still about 0,1 mm high in the middle - checked with feeler gauges and the "straight edge" that was my practice piece when I took a scraping class. I think this is due to wear and a bent table, the mill is a future project in itself and have several signs of abuse.
To further improve the manifold surface I'm thinking about scraping it. I have seen mentions of scraping gas tight seals, although I have only been concerned about sliding surfaces until now. Are there any differences in preferred depth, technique etc? I would assume so as the purpose is sealing and not oil retention?
