Scraping Stone - Burr Removal
Page 1 of 2 12 LastLast
Results 1 to 20 of 29
    Dec 2003
    suburbs of Ann Arbor, MI, USA
    13,038
    423
    1014
    Default Scraping Stone - Burr Removal
    So I was thinking about this...I try to practice hand scraping once a week in the shop, just on an extra piece of cast iron. Keeps the muscles loosened up and I place some random sharpie dots down as part of the exercise, try to scrape those off in a single short stroke, in order to practice the hand-eye coordination. So that aside, I was thinking...
    What sort of stone is best for burr removal?
    [also reading the end of this post had some ideas]
    http://www.practicalmachinist.com/vb...0/#post2315448
    Richard gave us all a stone in our class which I still have, but I was curious what the actual specs are...150-180 grit would be my initial guess. I don't have any others that coarse in my collection, thinking I might want to bring another one into stock
    May 2008
    Gilmer, TX
    381
    120
    214
    Shortly after attending one of Rich's classes, I ordered a couple of India stones from Enco. Looking back at my order and comparing the same items at MSC and Brownell's, shows only "Medium" for the grit. Since I placed the order within a couple of days after the class, I would expect that medium grit was what Rich recommended. He should be along shortly to enlighten us.
    Jul 2008
    Sydney, Australia
    3,726
    2056
    1287
    I'd be grateful for the code for the Enco stones if they're ok. I'm about to put in an order with them for more grinder wheels (I just picked up 69 at auction of various sizes and would you believe not ONE fits my little grinder ). I was informed last night that my good ol' diamond stone I use for deburring isn't the duck's guts after all so I may as well get those stones thrown in the Enco order.
    Jul 2005
    Cottage Grove, MN 55016
    7,566
    4085
    4518
    I have been buying this stone for years and it is the same stone my Dad bought. It is tapered to get down in the dovetails. Sometimes on small narrow doves I grind the thin edge sharper. As some know I break them in 1/2 when they are not flat by grinding a grove around them and snapping them. Some have an oops...drop them to break them..ha ha.
    As I stated in the other thread you have to check the new stones to be sure they are flat. Some are bent up to .010". I lay it down on a plate and hinge it. When they get dirty I lay 100 grit sand paper on a flat surface and give it a couple of squirts of windex and rub the stone on it. Then when you use the stone...rotate it so you don't stone a curve into your part your stoning.
    In Stock
    Price: $15.51 ea.
    Item Notes
    MSDS Available
    Sharpening Stones; Stone Material: Aluminum Oxide; Overall Width/Diameter (Inch): 1-3/4; Overall Length (Inch): 4-1/2; Overall Thickness (Inch): 1/4; Shape: Round Edge Slip; Grade: Medium MSC Part #:00579425 Brand:Norton Big Book Page #:1054 Mfr Part #:61463687150
    Same one but cheaper:
    Home / Abrasives / Files, Sticks & Stones / Stones / Sharpening Stones / #05111265 Print Email Page
    Made in USA - Sharpening Stones Stone Material: Aluminum Oxide Overall Width/Diameter (Inch): 1-3/4
    Price: $11.23 ea.
    I also buy the rectangular bench stones and grind a 45 deg knife edge when i am doing big ways like a Centerless grinder and the round stone with finger groves one side rough and one side smooth. Many Blanchard Grinder shops use them. I have never had much luck using a hard Arkansas stone.
    You have to be careful with a med grit Indian not to over stone, but as Matt can tell you I show everyone how to use their finger-nail to slide over the scraping to hoke / feel the burr and then stone and feel again. It is important to learn to stone too. So many things to learn how to do.
    I will try to find the other stones and add them in another post. Rich
  5. Likes Pete F, rjs44032 liked this post
    Jul 2008
    Sydney, Australia
    3,726
    2056
    1287
    Enco 317-1615?
    Jul 2005
    7,566
    4085
    4518
    Quote Originally Posted by Pete F View Post
    Enco 317-1615?
    looks like it. plus it's cheaper. MSC I think owns Enco too...I should be able to get them to meet or beat the price. Thanks. Rich
    Model #317-1615
    Low Price: $7.31 ea
    Availability: In Stock
  8. Likes Pete F liked this post
  9. #7
    May 2008
    Gilmer, TX
    381
    120
    214
    The ones I got from Enco were model# 317-1616.
    Their description says India Round Sharpening Stone. They have one edge that is round and the other is knife edge.
  10. #8
    Jul 2005
    7,566
    4085
    4518
    I will be ordering some in the next couple of days as i am going to take about 30 to the Norway and Swedish class, so I will probably buy about 50. I'll see if i can get a discount. I will buy from MSC though. I'll see if I can get a deal and let everyone know. Rich
    PS: Matt ..on the Canode...I have some but it will be a mess putting it in a little bottle. If you can't get any other...i can, but only for last resort ok. lol Rich
  11. #9
    Jul 2008
    Sydney, Australia
    3,726
    2056
    1287
    Ok thanks guys, I'll get the thinner one (317-1615) as I don't do big things.
  12. #10
    Jul 2005
    7,566
    4085
    4518
    Be careful as they break pretty easy. Does Enco have a wear-house in Australia?
  13. #11
    Jul 2008
    Sydney, Australia
    3,726
    2056
    1287
    Quote Originally Posted by Richard King View Post
    So would you suggest buying the thicker one then, or just a couple of spares?
    Regarding the other point, unfortunately Richard this is an area where we suffer from the small population and in particular the population density of the country. To help put it in perspective, Australia is around the same size as continental USA, but we have a population of just over 20 million IIRC. Nice if you want some time alone, and we have farms the size of European countries (literally), but it's not so nice if you want things that are considered somewhat specialised. We can get pretty much anything locally, but most suppliers just aren't interested in onesies/twosies. Want a hundred or a thousand stones, and they'll be happy to open an account and order that amount each month. The average hobbyist, ie somebody who just want a basic Chinese machine and cheap tooling, is catered for. Likewise industry is catered for. But the market for the guys with small shops or the serious hobbyist really isn't catered for. The market just isn't big enough to bother. It causes "challenges" at times
    A long answer to your question, but the answer in short is Enco doesn't have a warehouse here, but it may also explain why you often see reference to Aussie members bringing things over from the US, especially via USPS, to make it cost effective.
    Oh the other thing is, if something is available here off the shelf, a rule of thumb is to expect to pay around double what it would retail for in the US. Even though both things may originate in China. Welcome to Australian retailing and the concept "what the market can bare".
    Pete
  14. #12
    Jul 2005
    7,566
    4085
    4518
    I will only mark it up 25%...ha ha.....seriously, if you need something that I can help you get, let me know. Rich
  15. Likes Pete F liked this post
  16. #13
    Jul 2005
    7,566
    4085
    4518
    Do you have a copy of my DVD?
    I sell them on Ebay or if anyone wants one send me a PM and I'll give you a deal.
    Rich
  17. #14
    Jul 2008
    Sydney, Australia
    3,726
    2056
    1287
    Hey Richard thank you very much but I have a copy of your DVD and was just watching it the other night as a matter of fact (the wife and kids are away so I get control of the DVD for once. Ergh, the things we do for domestic harmony).
    I can recommend Richard's video to anyone who may be interested in this field. Available through ebay. I especially liked the section on power flaking, which is something I had never seen explained before. I guess the ultimate is to get apprenticed and "do your time", but next best thing is to attend a class and get taught by those who have, and just hope a teeny bit of that wisdom somehow manages to rub off. But failing any of that, for those of us who can't attend a class, then I think studying a video is probably the next best thing, and much better than a book. It may come a distant third behind being taught first hand, but I think videos are a very good way to learn.
    Pete
  18. #15
    Aug 2013
    NY
    2,298
    984
    798
    I like Norton medium India stone. Arkansas stones are too fine.
  19. #16
    Mar 2005
    near Rockhampton, Queensland, Australia
    5,502
    439
    2048
    Here is how I flatten a stone that you may find is pretty ordinary...
    Not uncommon for me to come across lots of different stones used for things like sharpening axes and knives and such... Usually they are pretty hollow and most are too coarse for scraping duty anyway...
    But to flatten them I do this...
    Get a piece of glass plate.... Glass plate really is not that flat and will bow like crazy if all you do is put it on something not flat... But anyway I use it as I had it on hand..
    If the stone is really really hollow I have garnet grit as used for sandblasting for the first stage.. 20140618_141135.jpg
    Mix it with hand washing detergent and rub around on the plate.. It will flatten the stone an an amazing rate of knots.. 20140618_141718.jpg 20140618_141920.jpg
    To proceed to a finer finish on the stone I use silicon carbide grit, and use it the same way after first washing the garnet off the glass... Bit of washing detergent with the silicon carbide grit and away you go... 20140618_142042.jpg
  20. Likes Richard King, Lurk liked this post
  21. #17
    Dec 2007
    Paris, France
    28
    8
    Sort of in the same direction, maybe I should start a new post, please let me know and or move this if it should be elsewhere. I'm looking for information on pull scrapping and pull scrapers in particular. I've only found one reference so far, what I'm after are information on length of handle, and the angle of the blade relative to the work piece and the handle. Any pictures or drawings would help!
    I am signed up for the December 2017 course in the UK! Looking forward to it!!
    Regards, Matthew.
  22. #18
    Jul 2005
    7,566
    4085
    4518
    Hello Matthew and you can google "Pull scraping practical machinist" and you will see a list of pull and hook scraping threads we have discussed over the years. Send me an email and I can forward you some pages out of a French and Swiss text book a former Swiss student sent me Just last week we talked about it in another thread and will try to link it here later. I am now figuring out the logistics of sending some straight-edges and my huge selection of tool there as I usually leave them home when I teach in Germany. I am sure you know I will be teaching 2 weeks prior to your class. Rich
    This an old thread: PULL Scraping
    The other discussion was in the post about what to teach a rookie scraper. it's long but Jergen wrote about scraping near the bottom.
    Pic of Puerto Rico student using a pull scraper.
    Attached Thumbnails Attached Thumbnails 20150716_170913.jpg   20150716_170902.jpg
  23. Likes mattinker liked this post
  24. #19
    Sep 2009
    washington
    226
    45
    Quote Originally Posted by RC99 View Post
    Hi All,
    I have another method for truing up your stone:
    I bought 3 Harbor Freight rectangular stones. They are fairly soft.
    I use the 3 plate method to true up each of the stones by rubbing them
    together in the 3 plate method.
    Then my stone that needs help gets rotated into the 3 plate mix. I make sure to
    true up my soft stones once a rotation so they remain true.
    Paul
  25. #20
    Jun 2001
    St Louis
    17,807
    1767
    2954
    I do not even like a stone for the purpose, I prefer a "burr file", which does not get loaded up , and also will not cut down too far.
    Simple to make, work well.
    Maybe I am just ignorant, but they seem to be a good option.
