Mud
- May 20, 2002
- South Central PA
I have a small gib with dirt embedded in the turcite surface that I need to clean up. It's about 3.125" long X .500 wide. I picture myself wreaking havoc scraping it normally with a flaking blade, how would you do it? I think a .003" cut off the top with an endmill would remove all the dirt and metal and be safer.
This gib rides under the way, holding the table down should gravity ever reverse itself, there's no load on it in normal operation so having perfect 40 point bearing is not needed.
