Seeking Straight Edge Selection Advice Plain/Combo with dovetail?
Results 1 to 16 of 16
    Jun 2008
    Bellingham, WA
    3,881
    929
    2004
    Default Seeking Straight Edge Selection Advice Plain/Combo with dovetail?
    I am considering purchase of a camel back straight edge in about 36" length. I am open to buying a rough casting, or a straight edge that may need to be rescraped. I would probably rescrape anything I buy in any event.
    I intend to use this on my lathe and knee mill. the 36" would be a bit short for the mill but I think, with care, I could get by with the 36 there. The part I am wondering about is whether it is better to get a combo straight edge with dovetail on one side or just figure on making or buying a prism or two for the dovetail work and get a plain straight edge. I am wondering if on the mill vertical ways if the combo would be awkward due to its weight and I'll end up with a prism there regardless. Due to the location of the mill it would be inconvenient to lay it down for scraping.
    I have been watching eBay and in addition have found a couple of sources for castings and one nice combo 36" camel back available locally. I just haven't yet pulled the trigger.
    Denis
    Feb 2012
    Victoria, Australia
    748
    228
    329
    Hi Denis,
    I've been lusting after one of these ceramic straight edges.. Item # 102278, Straight Edges ? Grade AA On Busch Precision, Inc.
    As far as camel back goes, personally I think the suburban parallel type I beam type would be more useful in the longer term,
    There's a bit of discussion on straight edge types here.. Which cast iron straight edge type is better?
    Ray
    Jun 2008
    Bellingham, WA
    3,881
    929
    2004
    Quote Originally Posted by RayG View Post
    Hi Denis,
    Ray
    Thanks for the link, Ray. It was a good discussion. After reading through it, I now understand why I was unsure of the best choice. Still not sure.
    Denis
    Jan 2003
    Columbia Missouri
    789
    35
    117
    My thinking is to "pull the trigger" and get the 36 in combo and get it scraped in. You then have the most capability in the one tool you have.
    You can add the others later if you wish, and by that point will know why YOU want them.
    The next step is to start adding different sizes of all the different types. Why? Because tools are what we use and think about. Some just resist temptation better than others...
  5. Likes dgfoster liked this post
    Virginia
    25,713
    7561
    8100
    Quote Originally Posted by dgfoster View Post
    Denis
    AFAIK, you are younger and stronger than I, but even so.... HANDLING any of these has ME convinced I'd sure as s**t drop it at least 'slightly' more than once over the longish course of the exercise.
    Struggling with something long enough - 24" minimum, 36" better - that I could deal with through enough iterations to get the job done before I damaged the straight-edge - and perhaps not-only.
    For now, I'm thinking I'll need a rope trapeze and an overhead push-trolley for the major moves.
    No joke.
    Might want to put the weight of each choice into your decision-making list.
    Bil
    Jun 2006
    Munich / Germany
    2,140
    342
    1069
    My bet is, that you will lay down the mill to scrape that way.
    Your neck and back will tell you what to do after pass #10.
    I'd buy a combined camelback.
    Nick
  8. Likes bebop, Screwmachine, dgfoster, Mark Rand liked this post
  9. #7
    Feb 2005
    Utah
    330
    382
    123
    I also would sugest you buy the combined camelback ... a prizum is handy to get under the lip of the dovtail but its far to "flexable" it will bend to match the surface its laying on, the camelback will also but to a lesser degree.Never scrape vertical if you can avoid it, you will tire quickly and the quality of your work will degrade, you'll try to rush through it and be unsatisfied with your results , and it's no fun. :->
    Cheers Don
  10. Likes Richard King, dgfoster, Nick Mueller liked this post
  11. #8
    Jun 2001
    downhill from Twain\'s study outside Elmira, NY
    11,036
    4126
    3854
    No one tool will do it all unless most of your machines have slideways under about 30" long. This is because of weight (personal lifting limitations) and the awkwardness or even impossibility of using tools big enough for "larger" ways on small compounds, cross slides, etc.
    If all the ways are smallish, an 18" to 24" long fitters straight edge might come close. This is a parallel beam style, with at least one square edge, and at least one dovetail. It will not be wide enough to do BP size machine columns in one hit, and is too short for the table ways. But it comes close on smaller machines.
    Add a 48" camelback, and then everything on a BP is accessible, at least. It will be a little tough to do the table way dovetails but can be accomplished with care. The thing is, the 18 - 24" fitters SE will be almost ideal for knee and apron ways if it is wide enough.
    Add a 48" prism, or a 30" or longer combination SE with a dovetail edge wide enough to cover any of the ways, and most machines on the order of a BP are accessible and more or less convenient.
    smt
  12. Likes dgfoster liked this post
  13. #9
    Feb 2014
    st. louis, mo.
    10
    Does any body know where or how to get your hands on these straight edges Dennis
  14. #10
    Jun 2008
    Bellingham, WA
    3,881
    929
    2004
    Quote Originally Posted by toolman40 View Post
    Toolman, that is a very good question. Finding a rough casting or finished 36" camelback with a dovetail edge is not easy. I did follow up on the two leads that were provided in the thread you started. Craig Donges is selling a well-proportioned rough castings for a 36" c-back but it does not have a dovetail edge. The other fellow, Dermer, is selling a Moore-style box straight edge in 21" and 30" rough castings. Dermer also has a 18" rough casting with a dovetail and he is also selling a casting to make a precision scraped right angle
    21" Box straightedge casting $325
    30" Box straightedge casting $425
    18" Camelback casting $100
    10" Precision Angle casting $100
    It seems surprising that there are so few of the camelbacks for sale. I suspect that there are hundreds sitting around unused. But, once someone goes to the trouble of scraping theirs in, they are probably not inclined to sell it for what it would fetch.
    So compromise may be the name of the game. I am trying to keep as many leads open as possible. I am pretty sure that with patience one can be found. The idea of casting some comes to mind. But other folks have done this in the past and they do not seem eager to have another go at it. So that route must be expensive and/or a lot of trouble. I did check with a foundry here in Bellingham just to get a rough idea of costs, but it they only do non-ferrous casting. If I were to do a run, I think it would be a 36" with dovetail.
    Denis
  15. #11
    Jul 2006
    Australia (Hobart)
    3,468
    543
    2615
    I've had a total of 4 small (575mm) and 4 slightly bigger (640mm) parallel beam castings done from my patterns without dramas at the foundry. I'm thinking of making up a 900mm pattern with a wide/thick enough bottom flange to be machined for dovetail spotting.
    Can't see the point in a camelback one for my use and I wouldn't bother making one. OK, in bigger sizes there might be some weight saving but the flip side is, you can't use it to check levels by putting a sensitive machinist's level on the top. I have an 1800mm camelback straight edge, cost me a slab of beer. Makes a great wall ornament.
    PDW
  16. #12
    Sep 2006
    Stillwater, Oklahoma
    1,239
    77
    637
    Denis,
    You might talk to Martin Model & Pattern (Martin Model & Pattern - your online source for fine quality patterns and castings) in Portland. He has castings for a box square/parallel among other things but I don't remember if he has straightedges. If not, you might interest him in making up the patterns. He has a place to do the casting and is a professional patternmaker so would be in a position to generate a pattern quickly and well.
  17. Likes dgfoster liked this post
  18. #13
    Jun 2001
    11,036
    4126
    3854
    My experience over 20 years with 4 foundries is that when I go to place a follow-up order they go bankrupt.
    I have found where my patterns are after the last bankruptcy. But am not really in a position to order a batch at the moment.
    smt
  19. #14
    Jun 2008
    Bellingham, WA
    3,881
    929
    2004
    Quote Originally Posted by stephen thomas View Post
    smt
    I just got off the phone having had a very pleasant and informative conversation with Gary at Martin Pattern in Portland. Interesting guy who currently teaches industrial arts to adults in Portland and who is interested in promoting metal arts and as an important part of that hand scraping. His primary job is as a professional pattern maker. See his website posted a couple of posts up by TGTool. He sounded interested in getting a run of 36" camelbacks with dovetail going if there is enough solid interest to make it happen.
    I encouraged him to join PM and join in the discussion as I think he has a lot to offer in terms of experience in industrial arts in general, but his background as a life-long professional teacher and his experience as professional metal caster may be helpful as well.
    My apologies to him if I did not get all the above info represented accurately.
    Denis
  20. #15
    Feb 2014
    st. louis, mo.
    10
    PDW Could you e-mail me information [email protected] on what you have in straight edges I would appreciate it. Thanks Dennis
  21. #16
    Feb 2010
    ch
    2,093
    194
    274
    Denis
    these prices are very expensive. i can get a 750 mm din 0 camelback for $350 (without tax).
