Selection of Straight Edges in need of resurfacing - no suitable referance to start
Page 1 of 7 123 ... LastLast
Results 1 to 20 of 131
    Feb 2014
    Peak District UK
    136
    183
    45
    Default Selection of Straight Edges in need of resurfacing - no suitable referance to start
    Appreciate this question will have been answered many times indirectly - (I'm still reading threads).
    I have acquired a selection of cast Iron Straight Edges (4 @ 6ft) 1 @ 5ft, 1 @ 4ft & [email protected] c3ft - widths vary from 2" to 4" ( & a good 2ft in proven condition) I have a 18x24" granite in good condition.
    The older SE working faces were all badly rusted up and whilst they show some signs of scraping approx 30- 40% of the faces are pitted and lost.
    I have need of a 6ft SE to begin my Hollbrook lathe refurbishment.
    My question is what would be the most efficient/ effective way to re-scrape the working faces of the SEs so that I can put them to good use ?
    I had imagined working the 6ft units to each other to 'average them out', and then use these as reference for the shorter SEs - that however has now taken a knock having read the thread earlier this year about the Whitworth 3 plate method (Forrest Addy write up) - I should really read these threads more frequently !
    I appreciate that I could use the 2ft good SE and overlap it (6") working my way along and maybe do the 3ft first to then repeat the exercise on a 4ft, then 5 ft and finally 6ft ? i suspect the possibility of error building up this would be a less sure method.
    Any advise greatly received
    Mar 2013
    Washington
    196
    116
    153
    Is there a section of way on your lathe that you can use?
    It would would never be as good as a plate but with careful use of your 2'se and a level and a king way type tool I would think you could get a 6'section of way within .001
    Aug 2014
    bainbridge island
    803
    144
    203
    Why not use the 4, 6' SE's and average them?
    The issue with using a shorter se to make a longer one is the error is squared.
    If you have a 2' se that is out by a tenth, the best you could make a 4' se would be convex or concave by 4 tenths.
    So if you use the 2 to make a 3 foot, then use the 3 to make the 4, you need another 3 or 4 foot unit to correct the two longer units to eachother.
    So what im saying is its going to take less time using the three plate method to scrape the 4 6'ers, then use them as masters to do all the others.
    Or just buy a 6' granite se and when you're done sell it
  4. Likes Milland, Lurk liked this post
    Feb 2014
    Peak District UK
    136
    183
    45
    johansen - thats what I was thinking with respect the errors. Cant afford the 6ft granite even short term.
    Hbjj - as far as the lathe bed goes - the only possible section not worn is badly mauled (shes not had an easy life by the looks of her.)
    mat
    Jul 2006
    Hillsboro, New Hampshire
    4,755
    1071
    3272
    Quote Originally Posted by Lurk View Post
    mat
    Johansen has it right, take the four 6' (or best three of them) and do the classic rotation spotting/scraping against each other until you have three (or four) good references, then use those for the remaining edges. Be sure to support whichever is the base for the moment well, such that it's not bending or twisted by gravity or clamps.
    If the pitting is really bad and you want it gone you may want to mill or plane them first, but it might be easier to put up with some small voids rather than find a place to cut them first.
    Feb 2014
    Peak District UK
    136
    183
    45
    I can put up with pitting as long as the surface is useable. I think as things stand, averaging out the best three 6ft SE with similar widths is my best bet. It will make for a good upper body work out and get my scraping muscles back into practice.
    mat
    Jul 2005
    Cottage Grove, MN 55016
    6,501
    3473
    3853
    I Googled Peak District and see your near Manchester. Member Tyrone who is a retired machine rebuilder is in Manchester and with his connections I bet he can find someone with a good granite table so you can test for the best 6' SE and make a stand so you can use that as a surface plate to do the rest. I see your near Shiefield too, there must be a machine shop or machine rebuilder near you that could help too. If not do the 3 plate method. Rich
    PS: I asked Demon and Tyrone to comment...2 of our UK rebuilders :-) asked Mark Rand too, but his mailbox is full
  9. Likes Lurk, Mark Rand, Paolo_MD liked this post
  10. #8
    Apr 2006
    Manchester, England
    7,037
    879
    4033
    Sorry Rich, Since I retired I'm out of the loop regarding getting favours from customers these days. The guy I could have relied on and who owed me plenty of favours retired and shut his shop earlier this year. He had a 10ft by 6ft by 1ft granite inspection table that I installed for him.
    Regards Tyrone.
  11. Likes Lurk liked this post
  12. #9
    Feb 2014
    Peak District UK
    136
    183
    45
    Quote Originally Posted by Tyrone Shoelaces View Post
    Regards Tyrone.
    The SE's are from a friend that was a machine re-builder (served his time at Cravens bros Manchester) he is semi retired in his 70's now. Many of his former clients are no longer in business and the surface plates they had long since gone - what we are recovering now are the items he purchased over the years as firms shut & sold up and he stored in old units (thus the rust). If you ever pass my way Tyrone I would welcome the chance to meet you - I am between Stockport & Buxton.
    cheers
    Mat
  13. Likes Richard King, Milland liked this post
  14. #10
    Mar 2013
    Washington
    196
    116
    153
    So how will you measure the twist in your straight edges?
  15. #11
    Feb 2014
    Peak District UK
    136
    183
    45
    Thats a good question.
    I have a couple of machinist levels good to 0.0005/10" which would be a start sat accross the width of the face. I am thinking the 3 plate 'averaging' will high light any issues and allow me to remove twist / warp. It a lot of work though especially with the heavier versions - the largest SE is approx' 65kg so thats sitting on its back while others are moved over it ! I guess much will become clear when I take the first rubs off 3 of the SE's
  16. #12
    Jul 2007
    UNITED KINGDOM
    4,335
    2050
    1851
    Sorry about the full inbox .
    I've got a 4 foot granite straight edge that I won't need until I re-do my surface grinder starting next year. It was grade 0 before I ever saw it, but I don't yet know how good it is now, since I haven't yet set up to use my autocollimator to check it. Plan was to re-lap my 3'x4' surface table and the straight edge to grade 0 before re-scraping the surface grinder.
    I'm about a hundred miles south south-east of 'between Stockport and Buxton' in Rugby.
    If you are happy to scrape three straight edges against each other to get straightness in a modified Whitworth technique, you can correct for flatness by using a precision level across the straight edges to detect changes in tilt along their length. If the Holbrook is one of the less ancient ones that's got a V and flat type bed, then you really need to use a level in a 'King Way' type device to make sure that the inverted V and the flat parts of the way are parallel with each other. Have you got or are you up to making such a level or kingway jig? I might have a spare 0.2 thou in 10" level vial somewhere that you could have for about £25!
    Edit to add:- I must have taken a long time to type this, If you are set with the levels, you can do the straight edges! A crane or hoist, even one of the engine hoist things can be your friend when handling them...
  17. Likes Richard King, Lurk, Paolo_MD liked this post
  18. #13
    Jul 2006
    4,755
    1071
    3272
    At that weight, unless you're a muscular youngster perhaps setting up a pulley block (with some shock cords for a little give) over the bench might be kinder to one's back. Let's you handle the edge being worked on a little easier, without adding any warp effect once placed on the base edge.
    Another thought - your friend who worked at Craven must have some good stories to tell. If there's any way you could feed him a few pints, plant him in front of a video camera, and get some of the tales on record that would be really interesting to many of us here. Even better if you can rope Tyrone into the deal.
    In fact, I bet there's dozens of folks on this site who it would be great to get oral histories from, I could see it as a branch of the Antiques (sorry guys) sub, or it's own standalone section. What say you?
  19. Likes Derek Smalls, Lurk, Paolo_MD liked this post
  20. #14
    Jul 2005
    6,501
    3473
    3853
    Thanks Mark. Lurk you should take Mark up on his offer. So much easier to have a teacher showing you how then guessing and double guessing each step. On your drive done , pick up Tyrone and you will get 2 for the price of lunch I bet. :-)
  21. Likes Derek Smalls, Lurk liked this post
  22. #15
    Feb 2014
    Peak District UK
    136
    183
    45
    Quote Originally Posted by Mark Rand View Post
    Hi Mark, thanks for the reply, Rugby - not too far away. I am looking at making up some form of Kingway arrangement for the bed ways & cross slide etc. A dedicated Vial would be handy to build in for sure and its the more accurate unit than my half thou' levels 7 level squares. The Hollbrook dates from early 1950's twin Vs & flats on the bed and white metal main spindle bearings (also badly worn - but that's another thread later ;-)) Drop me a PM ref the vial. Thanks mat
  23. #16
    Apr 2006
    Manchester, England
    7,037
    879
    4033
    cheers
    Mat
    Unfortunately your pal's story regarding the decline of the industry in his area is similar to mine. When I came out of my time in 1970 the Union ( AUEW ) used to produce a list of the wage rates of the Engineering Companies in my area. There must have been 30 companies on that list in 1970. This was just in my local area and only the larger companies that had Union representation.
    Today there is about 3 or 4 of those still in business with 1 or 2 new companies setting up in their place.
    They did a survey around that time ( 1970 )and in the Greater Rochdale area with the outlying smaller towns there were 30,000 people employed in Engineering and allied trades, foundry work, sheet metal work etc. A few years ago they did the same survey and it was less than 3,000 !
    The places that I know that are still left and were big enough to have medium to large inspection tables I could count on the fingers of one hand and they all had their own maintenance teams so I never got work with them.
    How places like " Craven " went out of business I'll never know. They were market leaders in the massive machine tool world. I suspect really bad management by the Staveley Group who took them over.
    Regards Tyrone.
  24. Likes Lurk liked this post
  25. #17
    Feb 2014
    Peak District UK
    136
    183
    45
    I have invested in a small 'action camera' with 32GB memory card for just this - in between re-telling his favorite tales a new one pops out - I plan to edit a few tales into each update of my progress with learning the skills and rebuilding the Hollbrook on my YT channel.
    Good to hear that it sounds of interest to others and not just me ;-)
    All the best Mat
  26. Likes Milland liked this post
  27. #18
    Jul 2006
    4,755
    1071
    3272
    Sounds great! Get Mark into that too, if you can. What's the channel?
  28. #19
    Feb 2014
    Peak District UK
    136
    183
    45
    I will post a link once I have a video of the 'folk' chatting - might have to sensor the language as it can get quite colorful at times. My channel is Lookcreations - I recorded my shaper restoration last year - a steep learning curve on that, supported by this forum - the resulting machine is a joy to use. lookcreations
    - YouTube
    All the best Mat
  29. #20
    Aug 2014
    bainbridge island
    803
    144
    203
    The three plate method does not have a twist problem.
  30. Likes Lurk liked this post
