I'm getting set up to start reconditioning a South Bend 10K lathe (light 10"). It will eventually be mounted on a workbench, but that would be a very awkward for scraping the ways. Since the lathe came with two SB cast iron legs (which I will eventually sell), my first thought was to bolt the bed to the legs and then carefully bolt the legs to the concrete floor (shimmed and leveled with a precision level, of course). This would allow me to scrape from both sides and at a relatively convenient height.
However, I then remembered Richard King's scraping class in Oakland a couple years ago where he told us about the importance of three-point support. Would it be better to mount the lathe bed at a convenient height on a narrow but solid wooden bench (still bolted to the concrete floor) with only the headstock end of the lathe bolted down and the tailstock end "floating" on a single centered support block?
Douglas
Douglas
