Hopefully this is the right section for this. I have a lathe that I purchased new three years ago and it’s cross slide is causing me a problem.
The top slide is secured by two bolts which pull the nuts upward inside of a circular T slot cut into the cross slide. I go back and forth between two angles that I use on the top slide and those two spots in the circular T slot have worn out completely where the nuts make contact.
I called Sharp and was told that they only warranty their machines for 1 year. Right now I’m waiting to hear back from the email that I sent because they refuse to talk about it or take an order over the phone. This is frustrating because I’m dead in the water until I get it repaired. If I have to replace this part every few years I’d rather figure out a way to modify it so it secures in an entirely different way.
If any of you have had the same problem I would be interested in hearing what you did to resolve it.
Thank you,
Marc
Thank you,
Marc
