Bearings gave out in the motor, then the bushings for the variable speed drive. So the motor shaft is banged up and at places 5 thou or more out of spec. So it's a given the shaft needs to get replaced.
Because the bushing gave out do you think it's wise to also replace the v-disks, or is that overkill? there is still some caked-on belt material but I think with a little bit of elbow grease it will come off, it was just stubborn with my first few attempts.
