slideway bolt hole filler/cap
Results 1 to 8 of 8
    Jun 2021
    Default slideway bolt hole filler/cap
    hello,
    I'm looking for opinions on the best process to fill or cap, some socket head cap screws, that are in the middle of the slideway. The cap screws are bolted through the slide way and into a lead screw nut. The cap screws are recessed .125 below the face of the way, and the slideway is freshly ground. The carriage has been freshly turcited and i need/want to fill or cap the bolt holes and scrap it flat so it won't tear up the turcite. How do you handle this situation, Thanks.
    Oct 2009
    Oregon
    6,171
    6602
    3501
    Chamfer the holes and assemble? Maybe pre-fill them with oil?
    Sep 2020
    NAMIBIA
    265
    112
    59
    Quote Originally Posted by iscgeoff View Post
    hello,
    If the slideway is covered anything will do. Plastic plugs, like on linear bearings. If not covered then you'll need something harder - bronze plugs might do.
    Apr 2013
    Damascus, MD
    1,700
    4993
    966
    An old way to protect the head of screws is to fill the head (and the recess) with glazing putty.
    however, if the screw in on a ground or scraped bearing surface, I second the suggestion of just lightly chamfering the hole and nothing else. Making a tight-fitting metallic plug spells big troubles when you will have to remove such screw.
    Paolo
  5. Likes JST, sfriedberg liked this post
    Oct 2010
    Oregon
    5,746
    5662
    2204
    I'd be inclined to just ease the edges of the counterbores and double check that didn't raise a ring around the holes.
    Are you expecting the Turcite to expand (slightly) into the counterbore and then get sliced off as it passes over the opposite edge of the bore?
    [Added in edit] Paolo beat me to the punch.
    Jul 2005
    Cottage Grove, MN 55016
    8,500
    4463
    4995
    Garwood's idea would be the easiest and you will need to champfer the sharp corners so it won't sheer off the turcite. In some applications I have had in the past, I have used Nylon or Nylatron that you turn so you can drive into the hole with a .001" press fit, then you can scrape them if your high. Or call Cody and ask him as they have a liquid product that is used to replace Turcite. Devitt or Moglice also sells Turcite too. If the hole are never exposed to the air then the chamfer method should work. Did a machine rebuilder do the work for you? What did they say? Devitt Machinery Company | MOGLICE
    Jul 2005
    8,500
    4463
    4995
    Quote Originally Posted by Paolo_MD View Post
    Paolo
    In the old days Lucus used to have bolt on ways with counterbored holes with cap screws that had steel plugs. They came off easy as we would set a mag drill on the way, drill a hole into the plug, fill the cavity with grease and slide in a dowel pin into the hole and hit it with a hammer. That worked like a hydraulic press and it would pop out.
  9. Likes Paolo_MD liked this post
  10. #8
    Jun 2021
    Quote Originally Posted by sfriedberg View Post
    yes, the concern was of possible slight expansion of the turcite and the possibility of chips collecting there .. we went with .001 press fit metal plugs, and then scraped them flat.
    the heads of the cap screws were machined to .125 below the surface. removal if necessary in the future will be pretty straight forward... drill tap and slide hammer.
    thanks for the responses..
  11. Likes Richard King, Paolo_MD, sfriedberg liked this post
