Stuck key removal
bellaireroad
Oct 4, 2015
Any tips on getting this stuck #7 woodruff key out? It is pretty chewed up over time. Has to come out to pull the rod from the case. Have used kroil and inductance heat, which got it hot enough to boil out the kroil. Tapped each side with a punch . It sticks out just far enough to get a needle nose on it that slips when you pull. Thanks
BTW. The first pic shows it before it was touched
Take a quality pair of Vise-Grips (one with hard jaws), grind the jaws flush, then with a slight bevel on the inner jaw faces to create a "nipper" profile. Use this to clamp down as far as you can on the key, adjust the grip as tight as you can (like a vise!), and pull/gently rock the key out.
If this fails grind the key flush, remove rod, recut keyway.
