Surface plate mounting question
shapeaholic
Stainless
Oct 14, 2003
Kemptville Ontario, Canada
I have just bought a 24x36 2 ledge granite plate to replace the plate I currently have.
I know that the plate needs to be sitting on the airy points which are specified in the standard GGG-P-463c
The question I have is, having a plate with ledges, do I use the dimensions of the top of the plate ( 24x36), or the bottom of the plate (24x30), to determine where the airy points are?
OR, am I just overthinking this?
Peter
Are there no pads at the Airy points on the bottom of the plate? Or marks from where they were?
L7
L7
WELL, I would have checked, but;
A) I haven't received it yet,
B) those potential marks are on the bottom of a 600 lb rock that is currently sitting on the floor.
SO... Not like I could just flip it over and have a look now could I??
I was asking the question so I could get a head start on the stand, so that I could lift it into place when it arrives (lift it once)
Peter
Calculate from the full size of the plate. In theory you could figure for the different weight distribution owing to the absent mass of the ledges but it's not that critical. An inch one way or the other from the theoretically ideal spot is going to be immeasurable by equipment that any of us have in our shops.
You are overthinking it. You're doing the right thing by arranging the correct mounting but as one of my co-workers used to say, "It's not particular to a dog's dick". I don't think I ever figured out exactly how much that was but I did get the general idea.
Not easy to give you an answer, unless you know the dimensions of the ledges and you calculate the distribution of the weight.
In reality, unless you need to do extra accurate work, it doesn't matter too much: being in the neighborhood of the right place is good 'nuf.
It is not necessary to lift it completely and flip it upside-down to see the pads (once you get it): jack up one end and inspect underneath with a flashlight and a mirror.
Paolo
On the plates I've dealt with, it is based off of the bottom of the plate. It really doesn't matter if the plate will get lapped as long as it's on those points all the time. Most likely if it's a used plate there's wear in the middle, if you move the points closer together based off the bottom, the plate may go convex just a hair which could work in your favor. Ultimately it wont matter if you have it calibrated. I run the calibration dept. at my work and I have yet to encounter a surface plate calibration tech who knew what airy points were, they only check to see it's on three points. If it's been sitting on the floor a while it can take several months to relax fully, I have run into this multiple times.
Peter
If you were overthinking it you would have bought a FOUR ledge plate!
Still doesn't come out "even", though, as the ledges are fixed width, not percentage-of-span width.
Which is why I'd work off the bottom shape/dimension.
