Testing Spotting Inks and Ink Rollers for Scraping - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
  1. #21
    Jul 2009
    Peoria, IL
    11,738
    51
    8992
    Quote Originally Posted by MCritchley View Post
    I have noticed the water loss in the canode as well. I was thinking about adding a bit of DI water a few drops at a time to re wet.
    Curious if anyone has done so.
    Canode is not water based. It's water soluble. Adding water to it will thin it, but now it has water in it and you will not be able to leave it on any metal surface or it will cause rust.
    I have some Canode and I had the same experience. It would be better to thin it with oil, but then it will no longer be water washable.
  2. #22
    Jul 2005
    Cottage Grove, MN 55016
    7,760
    4150
    4625
    I have never used plain water to dilute Canode. I use Glass Cleaner which I have always assumed had some ammonia in it. I also never leave anything wet with it during the night. Like I said I started using it in the early 90's if not the late 80's and it worked for me. Now I use it mixed with Charbonnel water based Prussian color as it darkens Canode. The Brothers over in Austria, who I remind you are pro's. Came up with the Canode Charbonnel mixture. They had purchased a Charbonnel thinner from the art supply place they bought it at and in failed as a bluing diluter. I started using the hard brayer to thin it out as I was successful the foam roller that BIAX sells. Biax also sells a hard roller too. They also sell Diament tube type that was preferred in Germany before I introduced Canode to Scandinavia and Germany. Jan is ordering a large order for his mates over there.
  3. #23
    May 2018
    AUSTRIA
    19
    12
    35
    It looks like Essdee offers a range of widths for their brayers, they can be ordered from the Amazon UK site:
    Amazon.co.uk: essdee brayer
    Thats right, but buy only the black "Deluxe" or "Professional" ones, the roller is maschine ground and the rubber has 60shore.
    From all the rollers we have used over the years, this one works best.
    Franz
    from the Lüftinger Brothers
  4. #24
    Jul 2005
    7,760
    4150
    4625
    Franz, I never received the class photo's??? I also never took photo's off your small glass jars we mixed the Canode in. Would you please add to this thread about the inks. Plus that brown Charbonnel thinner. What you tried.
  5. #25
    Mar 2007
    England UK
    1,868
    781
    762
    I have thinned canode with ordinary tap water - just a few drops in the 1.5ox bottle. It caused no issues. The yellow ink had thickened over a couple of years.
  6. #26
    Jun 2001
    St Louis
    18,219
    1960
    3096
    Quote Originally Posted by ewlsey View Post
    I have been thinning with water, which it seems to have in it to start with. The water dries out so fast that any rust issues have never come up. I was thinking of experimenting with ethylene or propylene glycol (antifreeze) to see if it would remain workable longer.
    you do have to mix it up well, or you get just a touch of the color, and it smears out. it's OK when well mixed. The problem is figuring out how much water to add. probably more than I think.
    I have been known to leave it on a straightedge overnight, and it has caused no problems. I do cover the surface with plastic after each spotting, to keep dust etc off it. Maybe that helps.
  7. Likes Richard King liked this post
  8. #27
    Virginia
    29,108
    7561
    9052
    Quote Originally Posted by Richard King View Post
    Not all have Ammonia, no. What I think they DO all have "in common" is Isopropyl Alcohol - then also various sulfones, surfactants, detergents, and such, depending on "brand".
    Isopropyl, bought directly in 5 Gal drums and larger, (as for the offset printing trade, "back in the pre-laser-printer" days), is sold with "some" water in it ELSE very soon attracts its own.
    See also "rubbing alcohol" at any pharmacy or supermarket. 30% water, is it?
    Could be it would be more predictable than glass cleaner and cheaper as well?
    Ethylene Glycol "motor" anti-freeze one does NOT want. Toxic in several nasty ways.
    "PEG" POLYEthylene Glycol - "plumbing anti-freeze", one usta buy at RV outlets to winterize a travel trailer or hunting cabin toilet- trap. Not to be mistaken for cran-apple juice and taken as a beverage, but at least a great deal less harmful.
    Spray and squeeze bottles are refillable/reusable a time or three, sold new, empty as well, so that's not a barrier.
  9. #28
    Jul 2005
    7,760
    4150
    4625
    I'll be teaching a class in a month down in Florida and will do some experimenting. I ordered a Essdee roller and will do some more testing. I will take my .00005" indicator and some gage blocks and see what sort of thickness we get with various bluing techniques. Just to inform the members. How about the others show it too with their favorite concoctions :-) and make this more interesting.
    Just to be sure everyone knows I always put to mush bluing on in the beginning say if the part is .005" out and as the part gets better I use less ink. Say you can slide in .003" shim stock under the straight edge I rough scrape that I call step scraping and blind scraping and use the yellow or red highlighter before bluing it up. But as I said once It is close say .001" I blue it up with to much bluing just in case I didn't stone off all the burrs. Also to those who are interested I started a private forum on Facebook. under my company name. King-Way Scraping Consultants. We have close to 500 members now. Some pro's and a lot of hobbyists. I have told all of them to join Practical Machinist too.
  10. #29
    Virginia
    29,108
    7561
    9052
    Seems to me there are two parallel tribes.
    The "followers" of the Old Skew oils and esters based pastes. Dykem, Stuarts, Diament, DIY, etc.
    The New(er) Skewl "acolytes" with the light-volatile marking and spotting media, be that glycerols. alcohols, water based, trace of Ammonia (or maybe not?). Canode and alterations.
    I'd guess the components are actually PUBLISHED in MDS data sheets for Canode and such? Why are we guessing about the chemistry, anyway?
    And is it really a matter of "professional" preferences, and does the media REALLY deliver different, better, or faster results?
    Or simply that those who do it all-day, every-day have a greater appreciation for easy soap and water clean-up instead of stained hands and equipment?
    whilst...
    Those who do it very seldom like a paste that can set back of the drawer for multiple decades, still be useful with nought but a dab of oil to make it ready again those rare times it is even used at all?
    And don't mind going through several pairs of disposable gloves of the sort I keep three different tribes of to-hand, cheap as they all be, Big Box, pharmacy, or online in bulk?
    It ain't "moving machinery" where gloves are a BAD idea, after all.
    I can't see even a long SE as hasn't had a proper meal in ten years getting so all-fired hungry as to suck you under it and grind yerazz into sausage as a large lathe or mill can do!
    "Glove-up". Even double-glove. Stain is no longer a Big Deal.
  11. #30
    Sep 2008
    Canada
    1,047
    427
    403
    I do most of my scraping projects in the winter in a shop that's well insulated and air tight. Avoiding solvents is, for me, a good thing when possible. I've learned to use Canode and alter my lighting to suit mostly because it's water/windex clean up. I agree, it's not as clearly visible and doesn't leave as nice a print as Dikem. Ease of use wins out tho... I might use brake solvent to clean up Dykem/Diament etc, but only in the summer.
    I was taught to use yellow Canode as a glaze reducer prior to printing, but find with good side lighting, I don't need other than for final 40ppi efforts.
    L7
  12. Likes Peter., Paolo_MD, Richard King liked this post
  13. #31
    Apr 2013
    Damascus, MD
    1,493
    4310
    851
    Bill,
    just a couple of quick comments.
    On MSDS sheets you do not find all the ingredients (chemicals known to be "inert" can be omitted) and you get at most a range of percentage in the whole mix, which allow the company more or less to keep their trade secrets for the fine tuning of the mix while still respecting the threat class for each of the components (e.g. search the MSDS for Canode and compare the results).
    Second, even the thinnest gloves will take away the sensitivity you need to detect dust particles in the bluing or the part you need to spot. At most, you can use them when during roughing stages, when you're still thousands away from flatness.
    Last, I think that the main difference between a more or less running fluid and a thick paste boils down to spreading techniques. Something more fluid is easier spread with a roller, whereas a thicker paste is somehow trickier to spread uniformly and it likely requires a shammy daub to spread it (and then you get into troubles with dust and dirt accumulating on the shammy).
    Paolo
  14. Likes Richard King liked this post
  15. #32
    Jun 2001
    St Louis
    18,219
    1960
    3096
    The propylene glycol is far less of a problem.
    Regular ethylene glycol would likely be OK, despite being a kidney poison, IF used only as a thinner in smallish quantities. I would NOT advise spraying it.
    Polyethylene glycol is used as a stool softener, it obviously is not particularly toxic.
  16. #33
    Virginia
    29,108
    7561
    9052
    Quote Originally Posted by Paolo_MD View Post
    Bill,
    That's a "given", so "water" is a possible, amines show up, ammonia, not:
    CANODE 2243 DIE SPOTTING INK by INK SPECIALTIES CO INC Material Safety Data Sheet #BPTCD.
    Extract for the blue one. Yellow will have a different pigment:
    Ingredients
    ISOINDOLINE, 1,3-DIMINO-; (PHTHALOCYANINE BLUE PIGMENT)
    CAS: 3468-11-9
    RTECS: NR3500000
    TITANIUM OXIDE; (TITANIUM DIOXIDE PIGMENT)
    CAS: 13463-67-7
    RTECS: XR2275000
    OSHA PEL15 MG/M3 TDUST
    ACGIH TLV: 10 MG/M3 TDUST; 9293
    SULFONATED OILS
    SORBITAN, MONOOLEATE POLYOXYETHYLENE DERIV.;
    CAS: 9005-65-6
    RTECS: WG2932500
    NONYL-PHENOL EMULSIFIER
    Patient: "Doctor, it hurts when I do that."
    Doctor: "So don't DO that."
    Take it on faith there will be particles from the prior pass and stoning. No need to touch them. Clear-way, same as you would if your hand had confirmed that.
    Done. Any stage. Go and have a look amongst the medical field as to how much a human sheds in sebum, complex organic acids, bacteria, fungi, accumulated and embedded soils, parasites and their eggs plus dead skin flakes all our lives. Not to mention hands not as clean as gloves "can be" right in the work zone. Ask any IC wafer worker or any Surgeon. It's THEIR disposable gloves I'm buying in boxes as well as the other Nitriles "painter's" type.
    Hands-on aren't always "cleaning" a surface once into uber-fine-fits. Hands-on are just as likely to be contaminating the surface. Even the neatniks among our grubby shops don't resemble an open-heart surgeon's OR nor an Intel IC wafer-fab clean-room.
    Paolo
    Well, yes. Absolutely. Got a 50-or more year-old tube of "Permetex" branded Prussian Blue as accident parked way in the back of a drawer. Only one I recall EVER as was ready-to-use right out of the tube. I still IS, oddly.
    All others need "adjusted" and worked-up a tad. Stuart's Micrometer is basically a "kit". Way too stiff to use directly.
    So yah - when it is being used every day of every week, I can see the attraction of a Canode that saves prep time as well as cleanup time. Time saved is paid-back as more work done and/or more money earned for the steady-working pro.
    Longer STORAGE life is worth more to the INfrequent user, lest we have to order "fresh" supplies each project and discard the not-so-cheap value of over-age goods too often.
    Not a "technical" issue, but still.. money has a vote, "according to prevailing circumstances", too.
  17. #34
    Mar 2010
    pacific northwest
    1,054
    6
    221
    I've only scraped one machine, but the dykem with thin disposable gloves worked ok. And I had it on hand. Cleaned the plate with mineral spirits. The hardest part was figuring out how to get a smooth even thin application. Eventually I settled on a paper towel, folded into a small square, and burnished the dykem in with it. Toss it every few uses, along with the gloves.
    I lied- the hardest part was lifting that surface plate onto the knee!
  18. #35
    Jul 2005
    7,760
    4150
    4625
    Way back in the old days before ink rollers we used white hard felt that was about 1/2 thick x 1" x 2" and it was wedge shaped to get under dovetails, or we folded a red rag in forth's then rolled it into a tight roll and wound electrical tape around that and spread on Dykem and red lead, as they were used more and more they got a waxy sheen build up and didn't leave as much lint as when they were new. BUT TAKE it from me those methods are old news. Rollers are they way to go.... Oh I just remembered we would cut the thumb off a pair of leather gloves or use a boot leather cut up into squares to spread it, but when going for precision bearing you HAVE to wipe the ink with your hands to feel for dirt as Paolo said.
    PS : A paint brush with 3/4th of the bristles cut off works great to get bluing under the dovetails. I use this method today. We also got dirty hands...lol When I used to do the IMTS show DAPRA Booth I would rub Canode into my hands and then wash them off with Go-Jo to the amazement to the attendee's. Then flake a small surface plate with the machine and then by hand. Oh I teach all the students to hand scrape and hand 1/2 moon flake the way we used to do it before we bought power scrapers and flakers.
