TOS SN500S Spindel aligenment - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 59 of 59
  1. #41
    Jan 2005
    The Netherlands
    5,766
    270
    1458
    Oke Great
    You found your adjusting bolts
    The one thing happening now perhaps (and I say perhaps) the spindle is pointing upwards
    Or the spindle was pointing downwards at first ??
    If the gap was taken out and put back at some time the headstock needs adjusting
    But that also means the lathe without the gap has a headstock out of alignment ????
    Demon
    The picture is a bit unclear but to me the bolts are not pushing the headstock but the casting of the bedways under it
    You are bending the bedways so to say Not twisting
    Peter
  2. Likes smic1978 liked this post
  3. #42
    Feb 2018
    DENMARK
    195
    11
    133
    Quote Originally Posted by Demon73 View Post
    Sweeeet! Chalking that one up as a win for the forum!
    One thing bothers me a bit, If you managed to get it over without loosening the main Headstock bolts, might mean theyre on the loose side? Maybe Tyrone or Peter could comment on that.
    That said, if the machines doing all you need, then maybe let sleeping dogs lie and get it back earning.
    Cheers
    D
    I don't think you have to losen the spindel and gearbox to adjust here. I think it's meant to just brute force the spindel alligenment. I think it's made to be able to flex there. Aslong as you have pressure on both bolts it should be fine.
    I spoke with my service/mechanical guy and he says it's how these tos lathes are ment to be aligned.
    It's cutting fine with the test cuts I did so I guess it's not lose. I will be doing some more testing and cutting when I get some free time in the shop.
    Sendt fra min EML-L29 med Tapatalk
  4. Likes Demon73 liked this post
  5. #43
    Feb 2018
    DENMARK
    195
    11
    133
    Quote Originally Posted by Peter from Holland View Post
    Oke Great
    Demon
    Peter
    Yes they are pushing between headstock and ways as far as I know. I think it's able to flex between the ways and the gearbox.
  6. #44
    Mar 2013
    Surbiton, surrey, UK
    1,601
    1946
    1003
    Youve lost me tbh Peter.
    My guess is those bolts could be pulling a couple of opposing wedges or similar that moves the headstock.
    Edit:-
    Sorry Peter, I think I now see what you mean. I thought those were bolt heads going 'into' the bed and under the Headstock, now ive had a closer look they seem top be going into the gap and being wound out to bare on the bed.
  7. #45
    Feb 2018
    DENMARK
    195
    11
    133
    You turn one lose and tighten the other one more to adjust. And then when you turn straight you tighten the lose one back.
  8. #46
    Feb 2018
    DENMARK
    195
    11
    133
    Oke Great
    Demon
    Peter
    Yes it's weird. If I remove the gap the spindel will be off again I guess. Kind of weird to do it this way.
  9. #47
    Mar 2013
    1,601
    1946
    1003
    Quote Originally Posted by Nikolaiownz View Post
    Yeah that sounds about right, just wondering if them headstock bolts want tightening up I know theyre a bit of a ballache to get to
    Edit:-
    Sorry, I missed this reply earlier, I see what you guys are saying now, those bolts screw into the gap and press against the 'bed' under the headstock? Not seen that before lol, but the maintenance man seems familiar with it. Amazing to think it can bend things around that much. Be interesting to see where the spindle is pointing now
  10. #48
    Feb 2018
    DENMARK
    195
    11
    133
    Edit:-
    It can point to the moon I don't care. As long as I turns fairly straight TOS SN500S Spindel aligenmentTOS SN500S Spindel aligenment
  11. Likes Demon73 liked this post
  12. #49
    Mar 2005
    near Rockhampton, Queensland, Australia
    5,534
    439
    2064
    Looks to me by the photo's the headstock aligns by the main V, like the US design of lathes.
  13. #50
    Mar 2013
    1,601
    1946
    1003
    But theres people here that wants to know lool
    Test Results
    8b: 0 / 0.01mm
    8a: 0 / 22.lol
    Lathes new nick name - drill killer
  14. #51
    Mar 2013
    1,601
    1946
    1003
    Quote Originally Posted by RC99 View Post
    It does look that way, and from the plans it looks like the headstock bolts go up through the V. As Tyrone mentioned, could see if a feeler gauge would go in anywhere.
    I have to admit, im having a hard time seeing how those jack bolts got such a result, the machine was turning .005 over 5 inch which is a fair old whack. Even makes me wonder if the headstock is sitting on some sort of riser. Id like to understand whats going on
    Wes did a decent video on adjusting the headstock. The adjustment bit starts around 3 minutes in shows the more normal 'push pull' setup ive seen before at 7:00.
  15. #52
    Feb 2018
    DENMARK
    195
    11
    133
    Test Results
    8b: 0 / 0.01mm
    8a: 0 / 22.lol
    I will see how krocket it is next time I get in the shop TOS SN500S Spindel aligenment
  16. Likes Demon73 liked this post
  17. #53
    Feb 2018
    DENMARK
    195
    11
    133
    I din cut a test bar and it was about 0.01 over 100mm taper. So I am getting close. I did check with a indicator in the top of the bar as that did not point up or down it looked like the same as the taper I can measure. So the spindel seems to be aligned fairly good now( am I correct?). I will need to check tailstock next.
  18. Likes Demon73 liked this post
  19. #54
    Mar 2013
    1,601
    1946
    1003
    Thats sounding good
    For the tailstock you can turn a spud and check it top and side near the chuck. That bit starts at 10:39 into the video.
    If the top measures well can cut two collars between centres to see how well it holds with the tailstock down the bed. Can also sweep the the tailstock quill as you did the test bar to see where its pointing.
  20. Likes Nikolaiownz liked this post
  21. #55
    Jan 2005
    The Netherlands
    5,766
    270
    1458
    I was thinking about it
    To make this work you have to when you assemble the machine new and with the adjusting bolts loose pointing the headstock down a bit Then with the adjusting bolts you can align the headstock up and left and right In alignment
    But there is a problem with the gap removed
    And every time you remove the gap you have to adjust the headstock when you put it back
    Peter
  22. Likes Nikolaiownz liked this post
  23. #56
    Apr 2006
    Manchester, England
    8,284
    1210
    5245
    In an ideal world with a 12" test bar in the spindle nose the free end of the bar should be up by 0.001" and be pointing towards the operator by the same amount. This is to counteract 1) the weight of the chuck and workpiece and 2) tool pressure. The same numbers apply to the tailstock.
    Regards Tyrone.
  24. Likes Nikolaiownz, Demon73 liked this post
  25. #57
    Feb 2018
    DENMARK
    195
    11
    133
    Thanks for the input guys. Will be digging some more into it next week TOS SN500S Spindel aligenment
  26. Likes Demon73 liked this post
  27. #58
    Mar 2013
    1,601
    1946
    1003
    Peter
    If it works the way you explained I agree, seems a weird way to design things if so.
    Be interesting to see how things move when those bolts are let off. If the head springs back it suggests they're flexing something, if it stayed put then they've moved something. Its all a guess till its apart or can ask the guy who knows eh.
  28. #59
    Jan 2005
    The Netherlands
    5,766
    270
    1458
    Everything is made out of rubber
    Peter
