mikeyjones
- May 25, 2021
Hey guys -
I have a 3 jaw Buck Chuck that came with my LeBlond lathe. Noticing an issue with it that hopefully someone here has insight on how to fix.
Only 1 out of the 3 scrolls gets it close to true. To explain: using scroll A the chuck has < .001" runout at the jaws (as measured by a precision ground rod). Using scroll B or C, it's .01 - .015". I can repeat this all day by tightening the bar using scroll A, measuring runout, then loosening/tightening using one of the other 2 scrolls and measuring, then going back to A and repeating. Without rotating the bar or doing anything else - just by using scroll A, it goes back to .001" runout.
So what would the best way to get the other 2 scrolls back in line?
I've disassembled, cleaned and greased the insides already to no avail.
Any help is appreciated.
