Two-part paint gun operation adjustment ease when painting different objects.
rons
Mar 5, 2009
California, USA
What paint gun is easy to adjust on the fly when paint objects that are more involved than a simple panel.
Does Sata have the best hand controls, like the fan adjustment and pressure control. It can all be done
with the hand holding the gun. Other brands require a second hand to turn the air at the bottom of the handle.
Was the Sata design done for one hand operation? If so, customer feedback over the years?
I was in a Tech school automotive program, where we did a lot of painting. I had the below Sata 4000 B digital HVLP gravity feed gun.
I sold it after graduation from the program because I wanted an Iwata Supernova. Sata are great guns but it depends on your style of painting. If you like a fast gun, then the Sata is a good choice. I am slow and methodical so I want the Iwata. I also prefer the fan pattern on the Iwata over the Sata.
Yes, you can spray the Sata or any HVLP gravity feed gun with one hand. I haven't seen anyone use both hands.
You set the fan pattern and air pressure before you start spraying, by testing out on a large piece of paper. We never adjusted the gun while in the process of spraying vehicles. If the paint is not laying down properly, you adjust and test on paper. I sprayed primer filler, primer sealer, base-coat and clear-coat with the Sata; only solvent based paint. I sprayed waterborne paint with the Iwata, and it laid down very nicely the first time I sprayed. Some Sata guns are solvent only, mine was both.
This YouTuber is the best when it comes to HVLP spraying.
The Gunman - YouTube
I am a member in the below forum; they specialize in HVLP spraying. The folks on this forum are one of your best sources for advice.
Southern Polyurethanes Forum
