Brandenberger
Hot Rolled
- Sep 19, 2017
Hi,
I scraped the column of my VN 22LU and while reinserting the feed shaft, I found
the bearings to be pretty rough, so I decided to remove them for replacement.
I figured I'd post some pictures because few people have probably been into this part
of the machine (and hopefully won't need to!).
I had found a document online (written by a Henry Arnett) which describes a procedure which I didn't use because I already had the machine on its back for scraping. His procedure removed the locknut on the sprocket shaft, then the housing for the shaft (2L-234) and slide the shaft into the column, allowing the vertical bevel gear and bearings to be removed once the locknut on the bottom of the machine is also removed.
On my machine, here the casting 2L225 has been removed from the bottom.
The view from the bottom of the machine. Interestingly, the casting was scraped to fit the machine machine base casting, with a gasket to seal it, and then lead was poured around the joints between this casting and the machine base and column castings.
Rear oil sump for the chain drive sprockets that normally would be at the bottom of the column.
Front end with bevel gear arrangement.
The whole casting with all the parts. Note the chunks of lead that sealed the gaps were quite thick in some places (1/2" or more).
I'm wondering whether to replace with lead, or some other kind of product (body filler?). What do you guys think? Whatever is used needs to stand up to cutting fluid and/or coolant. I might never run either, but I don't ever want to have to open up this area again!
I will of course use gasket sealer on the surfaces when they go back together.
Next step is complete disassembly and getting replacement bearings.
-Phil
P.S. I discovered how to post decent sized pictures again... at least on a Mac. If the picture filename ends in .jpeg, it will be compressed to a tiny size. But if they are .jpg, then are compressed to ~80kb or so, which is still a decent size.
-Phil
